Originally Posted by
landshark1
Awesome space! And even my wife said so!
Btw, how you like the MacMini+XMBC? It still couldn't bitstream HD audio with the current generation, correct?
That's quite a compliment, thanks!
I think that Mac Mini + XBMC is an excellent combination but my usage is more limited than most. I get XBMC crashes every now and then during database updates and I wonder if Windows or even OpenELEC wouldn't be a better choice to maximize the quality of the user experience.
As far as I know the HD audio bitstreaming limitation has more to do with OSX than it does with the hardware. Some of the Mac hardware will support it if you install Windows/Linux on the box but I'm not sure if the Mini will do that. For me it's a moot point, sadly, since my Meridian 568.2mm doesn't support HDMI audio anyway. It would if I bought some additional hardware and some weirdo cables blah blah FirstWorldMeridianProblems...
So, in summary,
Mac Mini XBMC
HD Audio bitstreaming = no
HD Audio conversion to 5.1 formats works fine via Toslink
