AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Samsung 2011 PNxxD7000 Thread
Official Samsung 2011 PNxxD7000 Thread - Page 67
post #1981 of 4112
Originally Posted by Jake NYC View Post
Hi All,
Owner of new 64D7000. Enjoying the tv so far, but came across a glitch of some kind-- In screen fit mode I shifted the screen position up several notches to block out some lines on the edges of one channel.
Now for some reason the position feature is greyed out in Screen Fit and I can't move the picture back.
I tried the "Reset Picture" option, but that just wiped out my settings without fixing the issue.
Anyone come across this or have advice? Maybe a factory reset in the service menu?
In the meantime I am using a different HDMI input and no issues with the other input.
Mystery solved: If you feed the set a 720P signal (I have my cable box set to pass through native signals on 720P channels), the 'screen fit' setting doesn't allow you to adjust the position.
post #1982 of 4112
Originally Posted by realeyz View Post
This sounds to me like its an issue with the type and/or amount of compression or maybe other shortcuts to minimize bandwidth issues being used by DirectTV rather than the set itself. I'm assuming you aren't seeing banding from other sources besides DirectTV?
I have not connected other sources to the TV yet, so I don't know. But your thoughts echo my thoughts regarding DirecTV compression artifacts and this problem.
post #1983 of 4112
Usually, a 1080p display will overscan on 720p, so this is prob why.
post #1984 of 4112
I talked to a guy in a local TV shop today that sells the 7000 and he said the buzzing issue has been fixed and newer builds shouldn't be buzzing. He also said that the fix is a simple part (some kind of rubber bushing or something) that mistakenly got left off many of the earlier sets. Apparently it's an easy fix for any local samsung authorized shop.
Don't know if this is true - he may just have been blowing smoke to try and sell me. He also said basically the same thing with the peeling issue and that he has only seen 2 come back for this. I didn't get any more detailed with it than that.
More like blowing smoke to me... I have a 59D7000, July Build and my set has a buzzing issue beyond 20 ft. I can hear it over TV sound at even with volume turned up at 14.. what is strange is that I can hear the buzz more sitting on the couch about 10ft within the front left side of the TV, moving to to the right you can barely hear the buzz. Buzz is audible all the way to a breakfast nook area behind the family room beyond 20ft. (more aligned towards the left side of the TV)
Originally Posted by LCD View Post
hey chrishman,
i'm fairly certain that plasma buzz is what you're hearing. all plasmas buzz to a certain degree and the sound is very directional. different people have different sensitivities to it. i also have a pn59d7000 and the buzzing bothers me also even though it is not very loud. of course, my wife, kids and four different friends hearing nothing objectionable, even when i mute everything. my seating area is about 5.5 feet away from the tv.
i believe that my tv is perfectly within spec and as good as it gets in terms of lack of manufacturing defects (no screen filter peeling, dead pixels, etc.), which is why i'm reluctant to do the whole exchange thing. i doubt that i would get a quieter unit back, although i suppose it might be possible. instead i've arranged for a return while i figure out what to do next.
if this tv could get a little brighter (inherent plasma weakness) and was as quiet as an lcd, i would personally consider it "perfect". as it is, i am still very conflicted about returning it because it really is a fabulous set.
best of luck on your exchange!
I'm the same predicament, besides the buzzing (as mentioned above) the PQ is fantastic, no other issues.. no peeling, don't notice fBr issues, black bars are solid and inky black... saw an issue watching Netflix the other day where the content which PQ was good but, suddenly drops off, just turns black for a couple of secs and back, this happened many times during the movie, I think it may be a Netflix issue though than the TV.
I also noticed I lost settings control while on Netflix cant change picture modes or even pressing info on the remote.
I may be following Chrishman's lead soon here, hoping I get a non buzzer like other lucky people here have.
post #1985 of 4112
Has anyone noticed horizontal lines on there set during dark scenes with ambient lighting. Mine (PN51D7000) does this even while turned off.
post #1986 of 4112
Hey guys, I posted the last Amazon sale if you used your Amazon Rewards card and was able to save a few users a few bucks...Well they are running the deal again but this time with Amex cards!
See the link
http://www.amazon.com/gp/feature.htm...cId=1000705101
post #1987 of 4112
Originally Posted by LarryInRI View Post
Automatic Brightness Limiter.
And from his posts, Turrican4D has a background in software development, he sells TVs in Germany, and he hates all Samsungs while loving all Panasonics.
Larry
Does ABL occur during video games?
Can you go into a bit more detail as to what this is etc..
thanks
post #1988 of 4112
Has anyone here seen the Samsung UN60D6400UF 480hz LED and compare it to the D Series Plasmas?
I saw one at Costco store, and it looks good. I prefer plasma, but had 2 Samsung plasma buzzers so far and thinking I should look at their LCD TV's.
http://www.samsung.com/us/video/tvs/...UFXZA-features
post #1989 of 4112
What's an LCD?
post #1990 of 4112
When you go look at the TV, make sure you look at it straight-on. Otherwise... it might not look so good.
post #1991 of 4112
thanks
ABL has been around for a long time. It is used in both CRT and plasma displays. The purpose of ABL is to limit damage to the device from occurring due to excessive high current. Because of the specific technology used in LCD displays, ABL is not needed. (Contrary to much misinformation found here and throughout the internet, ABL is not used to meet energy standards.)
Larry
post #1992 of 4112
Got my 64D7000 delivered today that I bought from Amazon.com (finally). Delivery guys took it out of the box and ............... the screen was cracked in several places. *sigh* I refused delivery and Amazon ordered a replacement, but said it might be another 3 weeks before the it ships. I was so close!!
post #1993 of 4112
OMFG - that's gotta hurt. I feel your pain.
Amazon and Samsung have got to be pretty peeved that the shipping companies break so many of these sets. You would think in this day and age shipping issues like this would be a thing of the past.
post #1994 of 4112
I wonder how the shipping companies handle this as they can always claim that it was damaged before receiving it.
post #1995 of 4112
It does suck but I believe these are made overseas so they have quite a trip with a lot of hands touching them
Factory to port, port to vessel, vessel to port, port to rail, rail to yard, yard to trucker, trucker to distribution center, DC to store, store to home
post #1996 of 4112
If the packaging is fine, then Samsung would eat it...if the box is damaged and the final shipper did not note the damage upon acceptance then I would assume they are SOL
post #1997 of 4112
I wonder what the actual percentage of damaged to non-damaged units actually make it through that labyrinth of handoffs to our front doors.
post #1998 of 4112
Deja Vu!. I had MY PN64d7000 delivered by BB home delivery subcontractor yesterday and its screen was cracked also!! I too refused delivery.
post #1999 of 4112
I bet this happens quite a lot now with these super thin screened TV's.
post #2000 of 4112
I bet Chris at Cleveland plasma could tell us. Yoo Hooo... Chris.
post #2001 of 4112
Yeah my first d7000 was delivered cracked!!!! I yelled at amazon and got a free bluray player and another 3d kit. Just got my new 59d7000 the other day and LOVE it!! I had a d6500 that I returned it. The d7000 looks much better out of the box then the d6500 which looked awful till I calibrated it a bit. The d7000 has a better picture and buzzes much less then the d6500 did, I can't hear anything with zero volume where I sit.
post #2002 of 4112
The Cnet review is up.
post #2003 of 4112
WTF...Samsung has rising black level problems now?! I know I haven't been reading up on the Sammy threads for a while, but when did this come about?
"Black levels on the D8000, meanwhile, appeared visibly brighter than on the D7000. That's mainly because blacks on the D8000 grew lighter as the TV aged--we measured 0.0071 Fl at the time of the review (150 hours), compared with 0.0092 after aging it 940 hours. That's a significant increase, and one that we expect the D7000 will undergo as well. On the other hand there's no way to tell how further aging will affect these TVs' black levels until we can age and test them more, so at this point our aging-related findings will not contribute to the TVs' reviews and scores. Furthermore, at the beginnings of their respective lifespans the two Samsung plasmas had very similar black-level performance."
Read more: http://reviews.cnet.com/flat-panel-t...#ixzz1TtPBh5Bc
post #2004 of 4112
Yep, this is new. We all knew about the increase in mll with CS engaged, but actually rising mll over time is new.
Strangely enough, the Panny has actually lowered over time...
https://spreadsheets.google.com/spre...3c&output=html
post #2005 of 4112
"Earlier this year we called Samsung's most expensive plasma TV, the PND8000series, the "Best overall TV of 2011 (so far)." Now that we've tested its less expensive brother, the PND7000 series reviewed here, that determination isn't as ironclad. Sure the PND8000 has a few extra features, chiefly a QWERTY keyboard remote and Web browser, but the two provide basically the same picture quality: outstanding, second among TVs this year only to Panasonic's much more expensive TC-PVT30 series, and better overall than the Panasonic GT30 and ST30 models. If you're in the market for a high-performance plasma TV and want the best blend of picture quality and value, the Samsung PND7000 is our new go-to recommendation."
Full Review: http://news.cnet.com/8301-17938_105-...it-less-money/
post #2006 of 4112
I would agree but Amazon, and Samsung are clearly not demanding higher and uniform standards on their logistic companies they worked with. My 59D7000 that replaced a D6500 buzzer from Amazon was delivered by Pilot by one person.. and have to help him bring it in the house. Handling/Shipping instructions clearly states 2 person delivery on the receipt.
The D6500 was delivered by CEVA, 2 person delivery, box came with a free large window/hole on the side of the box, these guys initially refused to install the stand and left the TV half in the box after plugging it in and were later called to return, to remove the TV entirely out of the box and install the stand by CEVA home office. Nice guys, unfortunately following vague instructions. That's a white glove service for you.
It's a crap shoot whether your set get handled properly from point to point during shipping.
post #2007 of 4112
Congrats. I like the D7000 much better than the D6500 as well. Unfortunately have the same loud buzzing issue as my D6500 it replaced.
post #2008 of 4112
How much do you guys worry about aging black levels?
My roommate watches on average 4-5hrs of tv everyday. Sometimes as much as 8hrs on weekends. Yes, I live with a couch potato.
Should I wait to buy the PN64D7000 until January when he moves out and I'm on my own? Or will it be fine?
post #2009 of 4112
If I knew a TV would have degrading black levels, I wouldn't purchase it at all. It's getting to the point where people just sort of expect this nonsense and put up with it.
I was getting ready to recommend this particular Samsung to a friend. I'm glad I read that review before speaking to him.
post #2010 of 4112
We need to confirm their findings before jumping to too many conclusions.
