AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Samsung 2011 PNxxD7000 Thread
Official Samsung 2011 PNxxD7000 Thread - Page 80
post #2371 of 4112
My PN51D7000 is currently on order. They have the PN51D8000 in stock now for $215 more.
Is the difference significant between these 2?
post #2372 of 4112
Originally Posted by bourmb
I agree about the 64 to 55 size difference. I temporarly have a Sony 46HX729 in my living room right now until the tv gets delivered. I have never had a 64 inch in the room as my original tv for the living room is a 60 inch XBR2. Therefore, the difference won't be as extreme. I love the bright picture of my 46HX729 and my room is extremely bright. I also don't want to worry about static logos and 4:3 bars as my kid's are always watching the tv and would never take into consideration of those issues.
Ok, those are good points and I will defer to your judgment. And since that model is the top model, I revise my statement. I'd take that Sony too if it were cheaper, as it has great CNet reviews.
55 is plenty big in a bright room.
post #2373 of 4112
Just saw this today from the CNET reviewer of the D7000 and D8000, and wanted to bring it up here:
http://news.cnet.com/8301-17938_105-...t/?tag=nl.e702
Highlights:
"Note the title "original picture settings," which means the post-calibration settings we publish in the review. The big caveat here is that readjusting the picture settings on the Samsung PN59D8000 at 1,500 hours caused its black level to return to 0.0074 Fl--essentially the same as the initial 0.0071 measurement at 150 hours. In other words, depth of black "drifts" higher on the D8000 over time unless you readjust it periodically, and so far the D7000 appears to be behaving the same way, although I didn't recalibrate it yet to confirm. (This finding corrects an earlier mistake I made regarding Samsung black levels over time; see No. 6 below for details.)"
And:
"As mentioned above, I originally indicated that the Samsung PN59D8000 became lighter as it aged (I made this statement in the performance section of the PN59D7000 review). The fact that the lightening can be corrected via calibration contradicts that statement. I will update the PN59D8000's settings and correct the PN59D7000 review accordingly."
post #2374 of 4112
I just wonder what he means by "readjusting picture settings".
post #2375 of 4112
Any suggestions for a wall mount?
post #2376 of 4112
Originally Posted by candler View Post
I did the Windows Notepad test and if you fill up the screen with Notepad, the screen dims quick to gray.
sounds like the automatic brightness limiter. this is a "feature" in most plasma tv's because supposedly if they were to display a full white screen at full brightness it will either cause too much power to be drawn, or the screen will over heat. it has nothing to do with floating blacks...
i have a pc hooked to my pn59d7000 and see this same thing. it doesnt really bother me b/c in normal viewing conditions you almost never come across a full white screen. also, with proper calibration it is less noticable. When the TV isn't running at full brightness all the time, it doesnt dim as much, and if the gray balance is even, its less detectable.
you might want to check out some other peoples settings that they reached using meters in this thread http://www.avsforum.com/avs-vb/showthread.php?t=1333561
post #2377 of 4112
so is the peeling stil happening
post #2378 of 4112
I'm almost certain he's referring to getting them re-calibrated. Later in the article he says that if you are going to get them professionally calibrated, and can only afford it once, try and wait as long as possible (in his example, about a year's worth of viewing) to take the black level rise into account.
post #2379 of 4112
Understood, but say you calibrate it, or have someone do it. A year later when you have a touchup appointment, does just the touchup tweak do it, or do you need to reset and do it from scratch. It's a little vague to me.
post #2380 of 4112
A simple adjustment of the Brightness control is all that is required. Use a test disk like AVSHD. It's trivial. (Oh, how I dislike the word 'calibrate' when it is used to mean 'adjust.')
Larry
post #2381 of 4112
finally pulled the trigger on the 7000 which is the set i wanted all along!
when the price rose recently i almost leaned towards the 6500 but prices leveled back out today on amazon and i pulled the trigger.
i am a noob to plasmas and have done alot of research, but still want to know about the 100 hour break in period. some ppl say with these new sets it is unnecessary....i want to use caution though.
i dont plan on using the break in slides, is it ok to just use lower contrast and brightness with full screen picture for the first 100 hours? no static images? thanks in advance and sorry for beating a dead horse i know this topic has been beaten to death.
post #2382 of 4112
Congrats on the new set. I think your best bet is to "don't be stupid" particularly in the first 100 hours. I used the slides to get through this period as quick as possible. You can just "baby" it along during the first 100 hours, no long gaming events, no static images for a long time, etc.
post #2383 of 4112
Larry
I agree. I own my own gear and that comment was very vague to me.
post #2384 of 4112
TV's here. I have a question seeing as this PN59D7000 is a JUNE build date how can I check to see if the o-ring fix has been applied? I checked around the bezel but could'nt notice anything, maybe I'm looking for the wrong thing? One more question I would really like to watch some 1080p movies but I heard that the letterbox picture can burn-in? How can I avoid that?
post #2385 of 4112
post #2386 of 4112
Here's a picture
post #2387 of 4112
Larry
Thank you for clarifying that Larry. I had just assumed that since he was a professional reviewer and knows what he's talking about, that when he used the term "calibration" he meant the process of breaking out the tools and instruments and taking measurements, etc.
A simple brightness adjustment is a much better solution!
post #2388 of 4112
post #2389 of 4112
Originally Posted by Tallen234 View Post
Here's some good news:
http://www.engadget.com/2011/09/01/s...sic&postPage=1
just fixing the link :-)
"Samsung's Smart TV update will feature YouTube 3D videos"
http://www.engadget.com/2011/09/01/s...ube-3d-videos/
post #2390 of 4112
1013 FW seems to be up for the 7000. Any one try to update?
post #2391 of 4112
Not going to be the guinea pig....would be nice if they posted release notes
post #2392 of 4112
1. Title
2011 PDP Firmware
2. Applicable Model
D6450, D6500, D6900, D7000
3. Carrier or Corporate Customer
All Customers
4. Description
This firmware makes TV available for 3D explore and Compassion apps.
This firmware improves picture quality on SD pictures.
Larry
post #2393 of 4112
anyone try the new FW yet and see if it affects calibration settings?
post #2394 of 4112
I have not yet. The last one did not affect settings.
post #2395 of 4112
Looks like someone at HDJ may have detected a slight black rise on their D7000.
post #2396 of 4112
Going to return my set today or this weekend. The buzzing was just too loud. I'll get a replacement from my best buy store. Also the update is not showing for me on the tv.
post #2397 of 4112
Just received delivery today - PN51D7000 and will hook up tonight.
Hopefully all will be ok?
post #2398 of 4112
I installed it via USB last night. The process went smoothly and when done, no user settings were changed.
The improvement with SD pictures is obvious. (I watch a lot of TCM in SD -- Directv.)
Larry
post #2399 of 4112
I am about to recieve a 59" d7000 next week. I downloaded the new firmware in anticipation and planned on doing it via USB.
Can you install these updates via WiFi instead?
post #2400 of 4112
Can you please provide a link for download and instructions.
I just received my tv today and plan to update tomorrow.
Thx
