Calculus,
Plasma (and LCD) panels do not interact with the magnetic fields emanating from speakers. That is a phenomena associated with the high energy electron beam in a CRT. Flat panels operate using a totally different technology which is not affected by magnets.
From what I can gather from the photo of your screen is a slight case of non-uniformity -- and a screen in need of a calibration.
WRT the non-uniformity issue: Only a panel replacement will cure this but it has been my experience that there is more uniformity problems with the later production of D7000 screens than has been discussed. My current screen has a similar problem such as you have but a bit less pronounced.
For the calibration problem: Since I assume that you do not have the required equipment to perform one, try reducing both the G-off and the G-gain settings. Be gentle though. First try changing G-off a click or two. If that doesn't get rid of the greenish cast, work with the G-gain. (If you previously had made changes to these controls, record the values before changing them. In fact, without equipment, I suggest setting them all back to the default 25 and starting with a clean slate.)
The offsets will effect the near blacks and the gains the mid and near whites. From your photo, it seems that the blacks at the top of the hills are green but this may be the result that the cinematographer desired. So you'll have to use a number of sources to check.
Larry
Larry
The picture is awesome though, like looking into a window to another world
