No, that sounds like the normal ABL circuit. It's designed to lower the brightness / power draw to prevent an overcurrent. What is being described is a decrease is brightness in several small and quick increments (edit: I resolved this via a factory reset). The ABL response is immediate and occurs in a single step.
Originally Posted by Zetherin
Yes, the factory reset and the disabling of all Eco options in addition to the Motion (whatever) fixed this for me also. It must be that one of the settings is stuck on delivery.
Brightness pops? Does that mean the brightness increases at random intervals? I actually do see this sometimes on the volume numbers when altering the volume.
I suppose. I have not seen this. It's best to judge these effects on high quality (1080p) sources.
I will re-iterate that the PQ on the 59D7000 improves upon my 58C7000, which, by most accounts, was among the best or next-best sets of 2010. The brighter output combined with the enhanced filter and better CR give the display LCD-like qualities with all the advantages inherent to PDP tech.
While it seems like a lot of hand-wringing, people post on forums to highlight problems, identify commonalities, and find solutions. It's not a self-congratulatory society (unless you own an 8G/9G Kuro
). If you're seeing frequent and visible changes in PQ that you deem are unacceptable (whether it's blinking from last year or random, fluctuating brightness), you should return the set. It's just a TV.
