Originally Posted by NWSD
Yes, but that is another 2 months of research.....just kidding. Honestly though there are a lot of choices out there, you'll just have to find what works for you. I'm no expert on Apple tv, but the last I knew it only streamed 720p. Again, I could be wrong on that. If you do get one you may consider jailbreaking it and putting plex on it. Plex just came out a big update I heard was nice. I say this without having any hands on with it, just researching as I'm in the same boat as you.
Well, I wasn't naming that product because I'm interested in it. It was just the first media streaming box that came to mind. There are a few good media boxes (good codec support) that I'm looking into currently. And I will use that in combination with the apps that are on my Blu-ray player, instead of streaming any media directly from the TV (now that I learned about this AVC thing).
I'm not even going to bother getting HD cable for this thing, as it really seems to be a waste of money. I can watch any show I want through Netflix or Hulu, which, even together, would run me less a month than many of the HD packages I see. Plus, I got this thing mainly for the blu-rays and gaming
. Kind of weird because I had set all the other apps to MOVIE and I thought that a single preset is consistently applied across all apps. I'm always startled how good VUDU's HDX streams look relative to Netflix. And no blinks in VUDU either.
