Originally Posted by
koffas
From what I've read about with the Panasonics, there can be a delay between the MLL shift and APL, making it very apparent. On my D7000, the effect is subtle because the effect is instantaneous with the APL of the frame (like an inverse ABL). And with a bright, high-APL scene, the iris is less sensitive to detecting the MLL increase.
Thanks for clarifying this koffas. I was actually going to ask you about this specific behaviour of floating blacks but you have read my mind
You see, on my previous Panasonic, a 54V20, I found the floating blacks to be intolerable due to the specific way they had implemented it (i.e scene change...wait...then black floats up/down...so annoying!). Whereas the floating blacks on my other Panasonic, a 42PZ800, are instantaneous with APL, and funnily enough I find it completely tolerable. Although on that set, the MLL itself doesn't change, just the low end gamma brightens/darkens depending on APL. But as mentioned, it's instantaneous, so on a scene change you don't even get time to see it happening.
For the Samsung though, I would have to see just how much the black level floats, and where exactly the threshold is. If the threshold is set high enough, and it's instantaneous enough, it *could* be ok.
Question: is it only the idling pixels which change in brightness, or is it the entire frame that gets brighter/darker?
