This will supposedly be available in April, but can be pre-ordered now from Channel Master.
http://www.channelmasterstore.com/HD..._p/cm-7001.htm
Has HDMI, component-video, S-video, composite video, stereo analog audio, and optical digital audio outputs.
The manual describes the EPG as "Simple guide lists the following program’s information of current channel." No grid-type display of all available channels. And there's no mention of a TVGOS setup procedure. So it must be PSIP-only and not hybrid TVGOS/PSIP as on the CM-7000PAL DVR.
or a way to loop the RF without it being modulated. I only see a CH3/CH4 switch but no OFF position.
That's not good, I thought the phone rep told you it was the same tuner as on the CM7000
. It's also outselling the TiVo Premiere & getting higher review ratings at Crutchfield. If it weren't performing well for me, I'd probably get a TiVo Premiere though
