I recently got my dad's old Harman Kardon T-45 Auto-Lift Turntable from his garage and some of his old vinyl. After ordering a new belt and cannibalizing an extension cord for grounding, I set it up to run through my Yamaha RX V667 and Polk RTiA7's. While everything is technically working, the sound quality is TERRIBLE. There's a ton of feedback and static to the point where listening to an LP is intolerable.
Should I try to fix this? What might be the culprit? I'm hesitant to go ahead and buy a new cartridge and stylus and find out that there's something else that's the problem. Or should I just go and buy a new turntable all together? I'm still going to listen to mostly digital music, so don't really want to spend more than $200 on a new player. Would a new entry-level player sound better than the old T-45 or is it worth it to try to fix it? If so, which is a good model to go with?
I'm also not sure how great of shape the records that I'm listening to are. I've tried several of his, and while some sound better than others, they're all bad.
Any feedback is welcome. Thanks!
