Originally Posted by robsis
Well...I just updated to the new firmware and now I can't get into SmartHub at all...it just sits on a blank screen and says: "updating". I even reset the whole unit...but no luck at all. Very disappointed.
EDIT: A hard reset by holding down the 'stop' buttom on the panel for 5-8 seconds resets the entire unit and did the trick (note that you do have to re setup the entire unit...). The reset in the setup menu is useless.
I can't tell you how many times I tried doing that on my player and it still wouldn't work. I finally had someone from Samsung say to send it in instead of its a router issue so I did. I got an email back saying they didn't find anything wrong with it. I asked if they had it hooked up to the internet and was told yeah they did. Got it back today, hooked it up the exact same way I previously had it, and it's magically connected to the internet now. Nothing changed on my side. Oh well.
