Hi all,
I'm new to HDTV, so forgive if this isn't the correct forum.
I'm shopping for a HDTV for someone, they will be using it in part as a computer monitor.
Looked at Princeton, perfect but too small.
Is there a larger HDTV that has connection for use as a computer monitor (like the Princeton?)? I forgot what the 15 pin connection is called.
Can any projection tv's serve as computer monitors?
thanks in advance for any help!
feel free to e-mail me directly, remove ENDSPAM from address
:confused:
:confused:
