My Onkyo is not sending LFE signal when present to the subwoofer hence no bass. If I disconnect and reconnect the cable from the subwoofer end, LFE signal is detected and I will get bass. I tried several cables and two different subwoofer but the result is the same. Before I drag the Onkyo to a repair shop, is there anything I could try to rule out setting/setup issues ?
BTW, I had the same problem with this receiver 2 years ago, took it to a repair shop under warranty but I made the mistake of not testing it when I got it back and I just stored it since I went separates that same year. Apparently Onkyo didn't fix the problem and just did a factory rest and sent it back. I now need to use it in the family room and it's still under warranty untill 2012 but Circuit City isn't where I bought this unit from. I wonder where I can file my warranty claim now that CC doesn't exist no more or could I still file with the Circuity City which is under new ownership or is CC's warranty handled by a different company ? Thank you all for your input.
