AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Official Sony BDP-S780 Thread
Official Sony BDP-S780 Thread - Page 21
post #601 of 681
LBJ2: Thanks for your help.
I don't get any notifications on my phone (HTC VIVID with android 4)
can you please post your network settings, IP, DNS, WEP/WAP/WAP2 ....
post #602 of 681
Piccolo: If you think you are experiencing a network issue connecting the S780 to your home network ( e.g. firewall/permissions) and your phone, its probably best for you to contact Sony Customer support directly and ask them to troubleshoot and walk you through this issue ( could be a number of things) . If you think its a problem with connecting your new HTC VIVID android 4 phone to your network ( this is a brand new phone model), then maybe a call to your phone service can help you as well. ( see on-line help below)
http://www.htc.com/us/support/vivid-...p/connectivity
post #603 of 681
Thanks, i will try that.
are your network setup as WEP or WPA/WPA2?
post #604 of 681
WPA2. ( This is recommended by many for best performance)
post #605 of 681
Just got this player today and I have a few questions:
1) What does Cinema Conversion Mode do exactly?
2) Should I select 1080p res or auto?
3) YCbCr/RGB - Auto or something else?
4) HDMI Deep Color Output - Auto or something else? Tried selecting 12bit & 10bit and can't tell the difference
5) Audio DRC - changed from Auto to off - is this accurate? I don't want to compress the sound in any way
6) BD Audio MIX - turn off to bitstream sound to my receiver?
BTW, I have a Samsung PS50C6500 TV.
post #606 of 681
I am using a Dlink Dir-651 router, according to the DLNA website it is not listed. do you this can make a difference?
post #607 of 681
Hello:
You can download the operating manual (pdf) by cutting & pasting this into your browser:
www.docs
.sony.com/release/BDPS780.pdf
( see page 27 for the above)
Auto: Normally select this. The player
automatically detects whether the
material is video-based or film-based,
and switches to the appropriate
conversion method.
Video: The conversion method suited for
video-based material will always be
selected regardless of the material.
Auto
Auto
YCbCr/RGB (HDMI)
Auto: Automatically detects the connected
TV type, and switches to the matching
color setting.
YCbCr (4:2:2): Outputs YCbCr 4:2:2 video
signals.
YCbCr (4:4:4): Outputs YCbCr 4:4:4 video
signals.
RGB: Outputs RGB video signals.
Auto
12bit/10bit: Outputs 12bit/10bit video signals
when the connected TV is compatible
with Deep Color.
Off: Select this when the picture is unstable
or colors appear unnatural.
Off or Auto
Yes
Hello:
www.docs.sony.com/release/BDPS780.pdf
post #608 of 681
Thanks for your help! I have the manual but still wasn't sure what to do because my old LG 390 didn't have any of those options.
post #609 of 681
I think you mentioned in an earlier post that you were able to stream from your PC to the S780? If so then your router is set up to stream over your home network.
If you can't stream anything make sure you Enable uPnP and Multi-cast Streaming under Advanced/Networking on your Dir-651 router
post #610 of 681
Ha ! These few settings are just the beginning. Once you've had this player a while you will realize all kinds of menus and settings/sub-settings. I think I think have found them all so far but wouldn't be surprised to find something else
post #611 of 681
Originally Posted by LBJ2 View Post
The Sony Operating Manual lists "some" of this info (on page 18. You can download the pdf here: www.docs.sony.com/release/BDPS780.pdf )
Video Settings • Picture Quality Mode:
Selects the picture settings.
“Auto,” “Custom1,” and
“Custom2” are available
only for HDMI
connections.
• Texture Remaster: Adjusts
the sharpness and detail of
the edges.
• Super Resolution:
Improves the resolution.
• Smoothing: Reduces onscreen
banding by
smoothing gradations on
flat areas.
• Contrast Remaster:
Automatically arranges the
black and white levels so
that the screen is not too
dark and the image is
modulated.
• Clear Black: Adjusts the
display of the dark
elements of the image. All
shading is not suppressed;
it allows beautifully
reproduced black tones.
Here's a bit more from Crutchfield:
http://www.crutchfield.com/p_158BDPS...=T#details-tab
  • Picture Quality Mode: You can select from 3 preset pictures settings (Standard, Brighter, Theater) for different lighting environment.
  • FNR: Reduces the random noise appearing in the picture.
  • BNR: Reduces the mosaic-like block noise in the picture.
  • MNR: Reduces minor noise around the picture outlines (mosquito noise)
  • I/P Noise Reduction: Improves the picture quality of Internet entertainment.
Cinema Conversion Mode: The Sony Blu-ray player offers two Cinema Conversion Modes - Auto and Video.
  • Auto: The player automatically detects whether the material is video-based or film-based, and switches to the appropriate conversion method.
  • Video: The conversion method suited for video-based material will always be selected regardless of the content.
@Smoker25 Here are a few more settings you can play with once you are watching a video....
post #612 of 681
Yeah, this player is pretty loaded with features. I could not believe how many Internet options this thing has. My old LG only had YouTube lol.
BTW, forgot to ask about Picture Quality Mode - should I leave it on Standard or do the Custom modes and features like Texture Remaster, Super Resolution etc. improve the picture even further?
post #613 of 681
Lol you read my mind.
post #614 of 681
Yes this is correct, didn't think of that. I can stream between PC and S780 also between Phone and Pc. so it must be something else. I contacted sony help desk 2 times and they are not much help.
post #615 of 681
Did you call into Sony or try to use their on-line chat service? ( Their on-line chat service is very basic and not much help at all)-- I recommend you call directly if you can--if first guy cant help you then ask for level-two support.
BTW are you able to connect the phone to your wireless network?
post #616 of 681
I used the online chat, will try to phone.
O yes my phone is on the network, I can stream from my pc using medishouse and Skifta.
post #617 of 681
I'd go standard to begin with. ( Blu-ray PQ on this player is very nice) The custom settings are numerous--perhaps too much so. I don't really use them anymore--unless I get one of those really grainy Blu-ray remasters. ( texture re-master seems to help ever so slightly to smooth out the grain.)
If you are not careful you can get more involved in these settings then actually enjoying the movie! But it is fun to explore.....
*If you are into 3D then do learn the 3D features/functions as these settings can have significant impact on the brightness and depth of the 3D experience
post #618 of 681
This may be too basic--but worth checking out anyway ( applies to most Sony devices with "rendering function"
http://esupport.sony.com/docs/imanua...remote_uc.html
post #619 of 681
piccolo456: Did you upgrade the firmware on the BDPS780 ?
post #620 of 681
Yeah, I'll just keep it on Standard for now. Don't wanna smooth out the grain or anything like that. I love grain!
post #621 of 681
Yes i did over the network.
post #622 of 681
Does anyone know where I can find the Euro version of M07.R.0579 firmware?
I installed the new firmware but don't want any of that Cinavia crap so I wanna downgrade it if that's even possible.
post #623 of 681
You cannot revert to previous firmware(s) on the Sony Sx80's (at least not as far as we know, there is no known method).
Jason
post #624 of 681
Jason
Well that sucks. Guess I should've waited before updating.
post #625 of 681
Hey guys, is the player supposed to be this loud while the disc is loading? Once the movie starts the player is pretty quiet (especially after the first few chapters) but when I insert the disc and it starts loading the menu or whatever the loading sound is significantly louder than my old LG. Is that normal?
post #626 of 681
Yeah,the loading sounds are normal
post #627 of 681
post #628 of 681
One more question: does the Downmix option have any effect on HDMI audio or is that only for Digital Out etc? My player is connected via HDMI to my receiver which supports every lossless codec so should I set this to Stereo or Surround?
Anyway, the player is amazing so far. I didn't think there'd be any difference in PQ between this and my old LG but there certainly is. The contrast in particular seems much better. The whites don't bloom and the blacks seem deeper.
post #629 of 681
Yes for HDMI. IMO you should do a surround sound test between the two options. I've got my S780 set at surround and seems to work fine with my Denon Receiver. I get plenty of surround sound effect out of my Blu rays.
There are plenty of surround sound test clips on Youtube you can stream to the S780 and use to test which Downmix configuration sounds best for your components. Here are a few to get you started:
http://www.youtube.com/watch?feature...&v=qlwXv9VXY80
http://www.youtube.com/watch?v=62iu3...eature=related
post #630 of 681
I got it working!!!
I phoned Sony and HTC, not really helpful I must say. HTC even had me reset my phone 
So out of desperation I started playing around whit het network and connected the S780 to the network using cable instead of wifi, and guess what it worked. Now I can see my S780 with my phone and the S780 can see the PC. But the Phone does not see the PC (pc is now on wifi). Seems the problem is with the wifi and the phone. If I connect the PC to the network using wire the phone will see the PC.
