AVS › AVS Forum › Industry Area › HDMI Q&A - The One Connector World › denon avr-4306 1080p direct with Win7
post #1 of 2
I have a Denon AVR-4306, PC with Windows7 Ultimate, NVDIA GForce GT430 using HDMI out for both audio and video, and a HDMI 1080P TV/monitor.
I have set the Denon to be Direct through for the video/audio.
When Windows boots up it recognizes the monitor as "Denon" and will only allow 480P resolution. I have tried to force the resolution to be higher by unchecking the "List Only Compatible Modes" checkbox and tried some higher resolutions. I can get some versions of 780p to work but the graphics are distorted.
Here's the catch, when I open Windows Media Centre, everything switches to 1080P. Everything is great until I need to switch to the Internet or window to some other app outside of Media Centre.
The PC's Gigabyte motherboard has built-in HDMI audio/video with 7.1 surround and 1080p, however, I could not get this to handshake at all to the Denon. I suspect that HDCP built into the motherboard 's HDMI was giving me issues.
The NVIDIA card does not have HDCP enabled.
If I hook up the PC direct to the TV/monitor by-passing the Denon, the PC sees my monitor correctly and provides the correct 1080P resolution.
My next idea was to try an ATI grahics card. I have a slimline computer box so my video card choices are limited.
Any suggestions would be greatly appreciated.
post #2 of 2
You'll probably get better results in the HTPC section of the AVSForum but let's see...
Your PC software (or at least the Blu-Ray software) is supposed to downmode to 480p or not display anything if HDCP is not enabled. So, that's a possibility.
Another thing to check is that you have the latest Denon firmware and the latest NVidia drivers. I find it difficult to believe that HDCP would give you trouble with the Gigabyte motherboard and a Denon so something else may be going on there.
If it were me and I was doing a new build, I'd take out all of the cards with the exception of only the cards I needed to run and see if the problem still occurs. You almost would have to do the same thing with the software to see. Perhaps boot-off a minimal 7/XP disc or just something to see if the handshaking occurs with none of the other software included. Might also make sure you are using only a single display while troubleshooting.
Sorry, but without much more knowledge of your setup, it really isn't possible to give a definitive answer unless someone has hit this situation before.
