Thinking of making some Orb clones, if not for the sake of the project then for the WAF.
Here's my rough plan, though I'd like to hear any thoughts you guys may have:
Drivers
I'll be using 3" full range drivers. Probably this Tang Band W3-881SJ. The downsides I initially see are the low power handling (15 watts RMS) and the impedance (8 ohm), making it difficult to do a "mod2" knockoff at 8 ohm, though I could add a resister in there if necessary.
If you have any suggestions for a better driver, I'd love to hear them. I'm looking in the $20-50 range.
Enclosure
I'm thinking of using 5" foam balls (here at JoAnn Fabric) as a base. I'll cut one side flat, then use fiberglass fabric and an epoxy resin to provide an exterior shell. (Added bonus: Maybe I'll do a final layer of black fiberglass or carbon fiber for a nice look.) I'll finish it up by hollowing out a majority of the inside , leaving some styrofoam for internal damping, drill two holes in the back for terminals, and add a mounting hole or some other method to attach it to a wall or stand.
I can't figure out how I'm going to secure the speaker to it. I'm thinking of possibly gluing it in, or making some sort of mounting bracket that I can glue on, and have threaded inserts on.
Future
Again, please let me know any thoughts or ideas you might have.
Drivers
Enclosure
Future
- I'm thinking if all goes well, I could do a "two way", and make an independent tweeter. Because of space limitations, I'd probably have to go with first-order crossovers for both speakers, but I could set it fairly high (7k?) since the 3" driver will be full range.
- Upgrade to mod 2 or mod 4
- 8" Subwoofer? I found 10 and 12" foam balls!
