AVS › AVS Forum › Video Components › Home Theater Computers › Denon AVR-4306 1080P Direct Win7 and Media Centre
post #1 of 7
I have a Denon AVR-4306, PC with Windows7 Ultimate, NVDIA GForce GT430 using HDMI out for both audio and video, and a HDMI 1080P TV/monitor.
I have set the Denon to be Direct through for the video/audio.
When Windows boots up it recognizes the monitor as "Denon" and will only allow 480P resolution. I have tried to force the resolution to be higher by unchecking the "List Only Compatible Modes" checkbox and tried some higher resolutions. I can get some versions of 780p to work but the graphics are distorted.
Here's the catch, when I open Windows Media Centre, everything switches to 1080P. Everything is great until I need to switch to the Internet or window to some other app outside of Media Centre.
The PC's Gigabyte motherboard has built-in HDMI audio/video with 7.1 surround and 1080p, however, I could not get this to handshake at all to the Denon. I suspect that HDCP built into the motherboard 's HDMI was giving me issues.
The NVIDIA card does not have HDCP enabled.
If I hook up the PC direct to the TV/monitor by-passing the Denon, the PC sees my monitor correctly and provides the correct 1080P resolution.
My next idea was to try an ATI grahics card. I have a slimline computer box so my video card choices are limited.
Any suggestions would be greatly appreciated.
post #2 of 7
Have you updated the firmware in your Denon?
post #3 of 7
I've used 3 different Nvidia GPUs w/ the 4306 w/o any issues. Mine boots at 780p then switches to 1080P(resized) once win 7 loads. At one point I had 7MC running at a different res than desktop 1080P(not resized).
The only issues I've ever had w/ my 4306 was losing HDCP on switching inputs or turning off w/ HTPC still on(usually only if done over a short time), I however haven't had these problems in quite some time.
post #4 of 7
I didn't see any available updates at Denon's site for the 4306 so I assumed none were available. There are some updates for other models like the 4806 but none offered for the 4306.
post #5 of 7
Does Windows see your monitor as "Denon" or does your HDMI monitor appear as the device?
post #6 of 7
Yeah my 4806 can be updated but my 4306 can't that I know of.
It see's it as DENON-AVAMP.
post #7 of 7
Does your HDMI out from your computer have HDCP enabled?
