well.. here was to hoping there'd be audyssey dsx and dolby plIIz... not so much. there isn't thx select plus2 certiifcation either which I was hoping for.. but I guess that can be lived without since we know denon is solid quality. oh well. guess my audyssey 7.1 front wide setup will wait...
also... I am interested in either the 2312 and 2112..
only differnece I can see is 15W with the 2312...
I dont know if I can justify the $200 price difference based on that.. can anyone else spot anything?
Dual subwoofer outputs
Picture adjust
I/P Converter and Scaler
Front HDMI
Trigger out
2-line front panel display (it appears that the 2112 is only 1 line)
Detachable power cord
For me these are all minor and not worth the difference but YMMV.
Damn, I was really hoping the 3312 would have XT32 in it. Doesn't seem like a major step up from the 3311?
MultiEQ XT32 requires high performance DSP's, your not going to find them in a $999 receiver. Currently on the Denon AVR-4311CI, Onkyo TX-NR3008 and 5008, Integra DTR 70.2, 80.2 and DHC 80.2 AVR's have this capability.
But there are many reports (including some from Audyssey, IIRC) that say otherwise--firmware updates could add XT32 to XT gear. It is the manufacturers who would rather you purchased a new receiver/pre-pro.
The 4311 uses two DSP's, 21367 x 1; 21487 x 1 32-bit Floating Point, while the 3312 uses the same 21487 x 1 32-bit Floating Point DSP now compared to the 3311 using a older, less powerful 21367 x 1 32-bit Floating Point DSP. While vendors could reprogram the DSP to do this, the overall design requires a second processor for XT32 which neither the 3311 or 3312 has as I understand it.
I still suspect they changed video processors, but don't see what they are using now? Like the usual typo's on Denon site. 3312 says its 105 watts on comparison page.
Hmmm, Airplay standard, one more HDMI input, video processor (unknown against flier), made in China now, weight drops 4 lbs, must have fans inside?
I'm thinking the weight is a typo as well. The 2312 is showing 23.8 and the 2112 is showing 22.5. I'm thinking the 3312 probably weighs a little more than the 2312. The 3312 now uses the same case as the other models so I'm sure it's dropped some from the 3311.
Denon has taken cost cutting to a hole new level with the xx12. One look at the rear panel, the legacy inputs are all gone, this is clearly AVRs for the newbies. Buyer beware should be clearly printed on each retail box, sucker.
I'm looking at the rear images for both the AVR-3312 compared to the AVR-3311, I see a SAT TV Sirius DIN connector missing, anything else that matters? Still got two s-video connectors, and component video inputs. Really very little differences. Hope you weren't looking at the wrong image.
Newbie, s-video, but thats not all, the amp are not full range rated.
The 2312 and 1912 are both improvements over the last year's model. I'm not sure what you mean by amp ratings but I don't see why the 1912 or 2312 will have any less power than the last year's version. With XT32 they are both a step up in my book.
so will the 3312 play digital signal (HDMI namely) over zone 2/3? This would be major, but im probably beating a dead horse
You never know the answer until they make the user's manual available. Certainly people have requested this feature.
Just see this paragraph online:
3 source / 3 zone output
The AVR-3312CI lets you enjoy a program source in the Main Zone (the room where the AVR-3312CI is located) and in 2 other rooms. The source can be the same for all zones, or you can enjoy 3 different sources in those zones if you prefer. The Denon Remote App controls all the zones from anywhere in the home making multi-room audio so much easier to enjoy.
yea thats what I read and wanted to confirm! I really hope this is an option... it would solve all KINDS of issues for me right now, is it REALLY that hard to implement anyways???
I compared a onkyo 608 to a denon 1911 and the amps sounded unlike, the onkyo amps sounded full and the denon amps sound hollow, the low end of the denon amps was missing at best. Onkyo amps in these price range are so much better its not even funny, denon is a embarrassment even with chinese shandards.
low end certainly isnt missing on my 2311... I have one of each, perhaps ill do a head to head comparison in my freetime.
next question, is it possible to still get full 7.1 and ALSO be able to bi-amp the front stage instead of using the heights? i guess this would apply to the 3311 as well...
The 33XX series are 7.2 AVRs ... so no.
Originally Posted by beastaudio
Custom Features
Phono input
7.2 ch preout
11 ch Speaker terminals Digital audio into zone preout
Zone 2 and 3 Video outputs
That part too
This has not changed in any of the 33XX series ... PCM 2.0 over optical/digital coax to Zones 2/3 or to Zone preouts.
Looks like Pocketcash created a new ID so he could post in the amp forum again.
I don't think that is possible but you wont be missing anything. Biamping like that does nothing. You won't notice any difference.
Your theater is awesome man. That screen is huge!
Thanks for the compliment, did every bit of it myself! With the exception of having a dedicated plug pulled Its been a tremendous work in progress but I dont intend on that stopping anytime soon
Seems like as soon as one aspect finishes, i get a bright new idea for something else. Wouldnt have it any other way tho!!
Yup .. no real changes in the 3312 as noted already.
1712, 2212, 2312, 3312 - June
1312, 1612, 1912 - May
Hmmm Big Picture article stated May for the IN-Command receiver series.
Twice had this posted
In Denon's core line of A/V receivers there are four new models: AVR-1312 (SRP: $249.99), AVR-1612 (SRP: $349.99) and AVR-1912 (SRP: $529.99), scheduled for April availability, as well as the AVR-1712 (SRP: $399.99), scheduled for June availability.
Seems like a month earlier pretty much across the board? Guess it would be nice to see a real press release.
Hello all, I've been looking at the AVR-3312CI for a replacement to my awesome (but aging) AVR-3200. My question is the THX mode, the Denon website mentions THX Ultra2-Certified but no check mark next to that saying it has it, I'm also questioning Ultra 2 on a sub 1k receiver, select sounds more correct to me.
Denon uses the same spec sheet for every model. If the item isn't checked off, it's not a feature (although there are many errors on their spec sheets from last year's models and some on the new ones as well). The only current model that is THX certified is the flagship 5308 at $5500 MSRP.
Damn how does Denon make the sale without THX? I'm back to researching this more now, also questioning why I think I want THX, I think it's because Onkyo, Pioneer, Yamaha offer it for the comparable receiver.
