Originally Posted by
Gary Lightfoot
You might be able to fit the L&R speakers in the wall, and make a baffle wall for the window to house the centre. That should allow you to keep your screen where it is and the pj throw doesn't get reduced.
Gary
I had considered that and you have a good point. My first concern was if the spacing would be correct for 16:9 imaging as well as 2:35 material. Looking at the photo of the wall again I think maybe it would be okay. I'm not exactly sure how I would handle the baffle wall in the window but I'm willing to try it in order to save my thrown distance and still have an AT screen. I really love my Ascend speakers and I think I would be sacrificing some pretty dynamic sound by going with in-walls but who knows. I guess it's time to start researching speakers to find something comparable to my Ascends but without a cabinet.
Here are the specifications on what I currently use.
For the L/R I have the CBM-170SE's
Typical In-Room Frequency Response 53Hz - 20kHz +/- 3dB
In-Room Sensitivity 91dB @ 1 watt / 1 meter
Frequency Response (Anechoic) 58Hz - 22kHz +/- 3dB
Sensitivity (Anechoic) 89dB @ 1 watt/ 1 meter
Average Impedance 8 ohms
Minimum Recommended Power 25 watts
Maximum Continuous Power* 200 watts
Maximum Short Term Peak Power* 400 watts
Cabinet Internally Braced 5/8" MDF, Magnetically Shielded, Bass Reflex via Rear Tuned Port
Dimensions H x W x D** 12" x 9" x 10"
Speaker Weight (each) 14 lbs each
Shipping Weight (pair) 32 lbs per pair
Tweeter (1) 27mm custom soft dome tweeter w/double-chambered neodymium magnet, ferrofluid cooled voice coil, wide dispersion faceplate
Woofer (1) proprietary 6.5” long throw composite polygel cone w/phase plug, non-resonant polymer chassis, rubber surround, shielded
Connectors (2) gold plated all metal 5 way binding posts
Inserts (2) ¼” x 20 inserts for simple mounting to wall mount brackets
*Unclipped peaks **Grille On
For the center I'm using the CMT-340SE
Typical In-Room Frequency Response 45Hz - 20kHz +/- 3dB
In-Room Sensitivity 92dB @ 1 watt / 1 meter
Frequency Response (Anechoic) 48Hz - 24kHz +/- 3dB
Sensitivity (Anechoic) 90dB @ 1 watt/ 1 meter
Minimum Recommended Power 35 watts
Maximum Continuous Power* 240 watts
Dimensions H x W x D** 7.5" x 21" x 10.5"
Weight (each) 26 lbs each
Shipping Weight (each) 28 lbs each
Tweeter (1) High-definition 27mm soft dome tweeter w/damping chamber and wide roll surround, ferrfofluid damped voice coil, wide dispersion faceplate, magnetically shielded
Woofer (2) proprietary 6.5” long throw polygel cone woofers w/phase plug, non-resonant polymer chassis, rubber surround, shielded
Connectors (4) gold plated all metal 5 way binding posts, bi-wire ready.
Inserts (1) ¼” x 20 inserts for mounting to stands
