AVS › AVS Forum › Display Devices › 2.35:1 Constant Image Height Chat › Help an old CRT user with transitioning to digital and CIH
Help an old CRT user with transitioning to digital and CIH - Page 3
post #61 of 137
Originally Posted by dropzone7 View Post
Hmm. I imagine most of my viewing will be video/movies and not test patterns.
Then you're missing out. Great direction and a fantastic plot with a twist at the end. Some nudity but no bad language. Usually rated as PG but under the counter versions are available if you know where to look.
Is the cylindrical lens easier to integrate than the prism type lens? I'm probably going with a JVC DILA projector.
I'd say both the same, but if you're going for a prism lens, get one with a corrector element and make sure your pj is within its recommended range.
Gary
post #62 of 137
Ok, looking for some advice on the screen now. Should I go for 2.35, 2.37 or 2.40? It will need to be acoustically transparent and I'm going for a width of 130" viewable area. I have read a bit about SMX and Seymour AV. It looks like Seymour list pricing on their site while SMX does not. That alone probably tells me the SMX is more expensive. I also looked at an Elite Screens fixed frame 2.35 from Visual Apex. This is by far the most affordable of what I have seen so far. It's about half what the Seymour screen cost and the SMX is probably the most expensive of these three but that's unknown until I request pricing from them I suppose.
post #63 of 137
They are priced similarly.
post #64 of 137
What do you recommend?
post #65 of 137
Both owners are friends. Send me a pm.
post #66 of 137
I'm starting to get a little worried about how much it's going to cost me to go CIH. I tore down a perfectly good CRT setup and now I'm wondering if I made a mistake. It will be months before I can afford a projector, screen, etc. I have an old Prismasonic lens that I don't even know will work in my room and reading about Isco lenses just got me depressed. What do you people that can afford those things do for a living? I would be out on my ass if my wife found out I spent that kind of money on a lens. Sorry to complain, I'm just getting a dose of reality I suppose and I really haven't spent much yet. Bought some used speakers, a new receiver and re-purposed my 5 channel amp until I can get monoblocks. Oh, what to do...
post #67 of 137
I picked up a second hand ISCO II and it works well with JVC projectors, especially at a long throw. ISCO IIs often go for under $1000 but don't come up that often. I would think a (used) corrected prism lens would be similar in price.
I would suggest making a screen using the material of your choice. It's cheaper than buying a complete screen, but you need some DIY experience.
Gary
post #68 of 137
Gary
Yeah, I missed an ISCO II recently because I thought it was a bit much for the age and condition. I haven't even tried this Prismasonic yet so I guess I should be patient and wait until I get a projector in here. I have made a few blackout cloth screens in the past and also did a Wilsonart laminate screen a few years ago. I'm okay with DIY but with the way the AT fabric needs to be tilted I wonder if I might be taking a chance.
post #69 of 137
Sounds like you're good to go, you just need some luck finding the right lens. Like you I can't really rationalise spending larger amounts of money, as much as I'd like to, but as I prefer CIH with an A lens to all the other options, it doesn't leave me any choice.
Speak with Chris of SeymoreAV regarding the AT screen material, and he can tell you how much tilt etc (I'll probably be doing the same in the hopefully not too distant future). He's a very helpful guy.
Good luck.
Gary
post #70 of 137
Okay, I'm currently looking at the following options:
1. Panamorph UH380 with no sled
2. Panamorph UH480 with ATH1 sled
3. Prismasonic H1200R (already have this but still yet to try it)
Aside from the UH480 having the sled, is any of these a good bit better than another? With my VP50Pro scaler would it be possible to use the UH380 in the light path at all times and manipulate the picture back to 16:9 for that content?
post #71 of 137
The UH480 is the newer and better overall performer of the choices! Especially with the sled it is definitely the best choice!
The UH480 lens' are all glass and fully multi-coated and features Chromatic Aberration and Astigmatism Correction. You can also purchase optional Lens Corrector Kits for the UH480 if you want to extend the throw distance beyond 20ft. I believe the throw distance sweet spot for mounting the standard lens without the Corrector Lens Kit is between 14.5 to 17.5 ft.
It also depends on what the cost of entry is! What kind of price can you get the UH480/ATH1 for?
...Glenn
post #72 of 137
Originally Posted by Glenn Baumann View Post
The UH480 is the better overall performer of the choices! Especially with the sled it is definitely the best choice!
...Glenn
Well, I'm bidding on one now in an auction but it will probably go for more than I want to spend. The reason I'm leaning towards Panamorph now is because I have a shorter throw than might be ideal for the Prismasonic lens. I think I would be right in the sweet spot with the Panamorph though. I honestly don't know what a good price would be for it.
post #73 of 137
dropzone7,
I have sent you a PM!
...Glenn
post #74 of 137
Well, I missed out on the UH480 and slide. Just more than I want to spend for this. I think I have decided to stop obsessing over the lens and just settle on a projector first. If the Prismasonic I have works then fine, if not I will live with it until I can find a UH480 I can afford.
post #75 of 137
By the way, I finally got SMX to price me on the screen I want. They were apparently too busy to respond to my email directly and sent my information to "Polivision". The price was nearly double what the Seymour screen would be so that ends that debate. I'm not looking at Seymour or Elite.
post #76 of 137
Didn't I see you were on the RS45 preorder list? I think sticking with that is your best bet. At the preorder price it is going to be a great projector for the money and zooming is almost certainly going to look better than using a cheap lens. Add in the convenience of the lens memory and you may forget all about finding a deal on a better lens.
post #77 of 137
Yeah, I'm on the list and even with the deal that it is I'm nervous about spending that much for just the projector. I'm looking at $1400+ for a screen and I have other things to buy for the room. I'm not sure I understand the way zooming works. I know that I want a 130" wide scope screen so that's about 55.4" high. The 16:9 image would be 55.4 x 98.6 and the 2.35:1 image would be 55.4 x 130.19. I have about 16' of throw to work with so I have no idea if zooming would work for me or not.
Well, if I'm reading this projector calculator correctly then maybe I should just try zooming first. I have my eyes on the RS10 because it's more in my budget and I can get this used and the screen for close to what the RS45 will cost or a bit more. According to the calculator I could do both the 16:9 and 2.35:1 screen sizes I want by mounting the projector at 16' throw and just working the zoom. I would get about 18 foot lamberts in 16:9 and about 14 foot lamberts in 2.35:1. Hmmm...maybe the lens can wait. Oh decisions, decisions.
post #78 of 137
Looks like 16ft is close to the min throw you could use to zoom. Probably a good thing since it will get you a little extra brightness to light that large screen.
The RS10 would certainly do the job, but the RS45 has so many PQ improvements and additional features that I think there is a much better chance of staying happy with it long term. And dont forget about the peace of mind of a full warranty. The lens memory alone will likely make purchasing an anamorphic lens unnecessary. It takes a good quality lens to improve on zooming and you can count that as money saved. Are you planning on sitting close enough to the screen where the extra resolution using a lens might be noticeable?
post #79 of 137
Yeah, that's another thing is seating distance. My room is small so the front seats will be about 9 to 9-1/2 feet from the screen and the second row of seats will be maybe 14 to 15 feet from the screen. It's closer than I would like but if I'm getting more than two or three chairs in the room I have to have two rows. This room is just a spare bedroom.
post #80 of 137
isco III and sled on ebay! Won't help your dune do 4:2:2 but WOW!!!! ISCO III!!!!
post #81 of 137
Yeah, I saw that! If only I had your money!
post #82 of 137
What row do you see yourself sitting in?(the money seats) The beauty of CIH is the way one seating distance can work so well for multiple ARs. The trick is finding the perfect balance of PQ and immersion. My thinking is to optimize everything about the money seats(row) and then figure out how to add additional seating. The average guest is not likely to notice PQ issues like SDE. If possible keep your seating ideas flexible until you get your projector and experiment.
post #83 of 137
Well, I have a projector finally. It wasn't my first choice but it gets me in the door of the technology I wanted. It's a JVC RS1 and appears to be in great shape. I have been running it for a few days just sitting on a box and projecting onto my soon to be retired 16:9 screen. Picture looks awesome to me although it doesn't have the CRT fade to black which I will miss. I guess the next step is to see if this Prismasonic lens will work or not. I'm thinking my throw is going to be too short for it with the screen size I want to use.
post #84 of 137
I don't think the RS1 scales for CIH. I know the RS2 does. Do you have a scaler?
post #85 of 137
I'm pretty sure he has VP50.
Mike
post #86 of 137
Mike
Yep, I have a VP50 Pro. I took my Prismasonic lens apart and painted the housing black. As soon as I get it back together I plan to test it with this projector.
post #87 of 137
I need some help with my screen wall. I have some inwall speakers that I want to use behind an AT screen. Just one problem, I don't want to mount the speakers "in" the wall. I have a large window right in the middle of that wall right where the center channel would be. I need to build some sort of framework to hold the speakers on that wall while also providing a substantial enough support for the actual screen. I'm starting to lean towards possibly going with Seymour AV Centerstage material only and attaching it to a DIY frame. I have to be very conservative with my space as the room has a short throw to begin with. I want the speakers, wall treatment and screen to be as shallow as possible (9-10" or less). My speakers are about 4-1/4" deep and I plan to cover the screen wall and window area with 1-2" of rigid insulation just like I made my DIY absorbers out of. The screen will then sit in front of the speakers, at least 2" I think is what I need to allow for breathing room. The speakers do have fully enclosed aluminum back boxes so I don't think NOT having them in the walls will be a huge issue. I have been running them for a while just sitting on the floor propped up against the wall. They sound pretty darn good already. Any suggestions on how I might make this support system for the speakers/screen?
post #88 of 137
Yep. You build yourself a baffle wall out of timbre and MDF. You must cover the baffle wall with sound absorbing material (1" convoluted foam works a treat) and you attach your frame to the baffle wall. This will solve many issues including light bouncing around behind the AT screen.
post #89 of 137
Just wanted to check in and let you guys know that I finally got around to trying out this Prismasonic lens with the RS1 which I recently purchased. I'm still using my 16:9 screen which is just leaning against the wall at an angle and I have black curtains on the sides of where the screen used to be so not ideal conditions for testing. I did a temporary setup with the projector and lens sitting about two feet off the floor on foot stools and placed about 16' 3" from my screen wall. My target screen size is 98" wide for 16:9 material and 130" wide for 2.35 material. That makes the height roughly 55". I will be the first to admit that I'm really pushing screen size in my small room and right now I'm okay with that. I also realize that I will loose a bit more throw distance once I get a baffle wall and proper screen up. Anyway, my point here is that after just some very rough and brief viewing I am impressed with how the image looks from this budget combo. After reading about prism lenses I was concerned about how things would look and I'm sure once the setup is more ideal I will notice some issues that I don't now but I must say I was pleasantly surprised upon my initial viewing. The image is still very sharp and clear with the lens in place and I see very little geometry problems at the edges of the picture, nothing I can't fix with masking or a bit of tweaking I think. I guess the bottom line is that I'm relieved that I may be able to live with this lens and projector for a while and just upgrade as budget allows. I don't feel the need to go drop thousands of dollars on an ISCO now or even a Panamorph with motorized sled. This remote control prism lens seems to do the trick for now. More to follow of course as I begin to get things setup. I'm really stumped on what to do with my front speakers and screen wall so that's next up.
post #90 of 137
Glad to see you like the lens. Your thread motivated me to revamp my
theater and go anamorphic.
