Just purchased the Klipsch QUINTET 5.0 Speaker System and now I need to purchase a subwoofer.
The Klipsch SW-350 8-Inch 350 Watt Subwoofer is designed to compliment the Quintet 5.0 system.
But I have an opportunity to buy the usually higher priced Klipsch Reference Series RW-10d - Subwoofer - for a price cheaper than the SW-350.
I'm concerned about buying a subwoofer that doesn't match up well with the other speakers, especially the Quintet and their small size. Also don't know about the advantages or disadvantages between down firing(SW-350) and front firing (RW-10D) subs.
Any advice?
Listening: 80% movies/20% music
Room Size: medium size living room, wood floors, 12 foot ceilings.
Marco
Any advice?
Marco
