Originally Posted by
nova0002
handshaking? Can you elaborate? Like it distorts the signal? Don't know about that, I connected the cable box directly to the plasma and it was no different than when I connected it through the Denon. The Onkyo just improved the picture, I don't think the Denon distorts it. Unless you're talking about something else when you say "handshaking"
There's various HDMI issues.
One problem that some people have run into, is signal problems, sometimes blamed on HDCP, the copy protection mechnsim that sits on top of HDMI.
Another issue is HDMI repeaters. A receiver operates as an HDMI repeater. The HDMI document I looked at was very terse about what this means. It says that a receiver should look like a source to a sink (TV) and a sink to a source. But it seemed to be mute on issues such as what happens when a TV is powered off. Does the receiver lose the information? If so, then when the source gets the EDID info from the receiver, it does not include the proper display properties. I had numerous issues with this due to Tivo changing it's setting just because I powered off my TV.
Yet another issue is audio. Cable boxes are bad with this, as is Tivo. When you change streams, like changing channels, audio may be lost for seconds, or sometimes even lost until you change something again - I usually fix this by pausing and unpausing Tivo.
So while HDMI offers the best option for digital video (as conversions are needed with component video,) and the best option for lossless audio, and the simplest wiring, it's not without it's issues.
