AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Official Sharp 2011 LC-70LE732U Owner's Thread [NO PRICE TALK]
Official Sharp 2011 LC-70LE732U Owner's Thread [NO PRICE TALK] - Page 118
post #3511 of 3787
I have the 732u and I love it!!!
post #3512 of 3787
Bought the 732 two days ago and love it. Tv is in very bright room with wall of windows. The cnet calibration looks great on a cloudy day or in the evening when there isn't direct sunlight in the room. If it is a really sunny day I have found in the standard mode with some minor color tweaks , it actually works pretty well as the sun shining in the room seems to cut down on the harshness of the colors and vividness.
I've inquired about having a pro calibration done and the two hi-def stores I contacted recommended using the tv for a minimum of 100 hours before having this done. Is this normal? To be honest, I'm really satisfied with the picture right now and I'm debating if it is worth the calibration at the moment. It really seems to be dialed in for blu-ray and hd programming.
Great tv!
post #3513 of 3787
For those people interested I started a thread called "newbie calibration device" in the calibration thread. Lots of good info in there for those looking to get into calibration at many different budget levels
post #3514 of 3787
I emailed sharp and asked if the 2011 models were going to get the smart central update and they said no. I really want YouTube and Skype to be available on the tv.
post #3515 of 3787
What is the "smart central update"?
post #3516 of 3787
All new ui for the tv that adds new apps including YouTube , Skype and others
post #3517 of 3787
Has anyone figured out RTI or Hex codes for Power On & Off, discrete inputs? I don't believe they're using Elite codes, nor standard Sharp IR codes.
Any help is appreciated!
Dan C
post #3518 of 3787
I received this from Sharp, can someone break this down into standard hex format?
CODE(15Bit)
code SYSTEM DATA HEX
c1 - c5 c6 - c11 c12.c13 c14,c15 CODE
POWER ON/OFF 10000 011010 00 10 01 116
ANT change 10000 100101 01 10 01 1A9
INPUT change 10000 110010 00 10 01 113
AV position 10000 000111 11 10 01 1F8
SURROUND (Front surround & Virtual Dolby) 10000 011101 10 10 01 16E
MTS 10000 000110 00 10 01 118
CC 10000 010100 10 10 01 14A
PINP ON/OFF 10000 100010 10 10 01 151
TWIN P SELECT 10001 100100 00 10 11 109
PINP CH+ 10001 110111 00 10 11 13B
SCREEN SIZE 10000 000001 01 10 01 1A0
PINP MEMO 10000 110010 10 10 01 153
PINP INPUT 10000 001010 10 10 01 154
PINP CH- 10001 001111 00 10 11 13C
DISPLAY 10000 110110 00 10 01 11B
SLEEP 10000 010110 00 10 01 11A
1(TV) 10000 100000 00 10 01 101
2(TV) 10000 010000 00 10 01 102
3(TV) 10000 110000 00 10 01 103
4(TV) 10000 001000 00 10 01 104
5(TV) 10000 101000 00 10 01 105
6(TV) 10000 011000 00 10 01 106
7(TV) 10000 111000 00 10 01 107
8(TV) 10000 000100 00 10 01 108
9(TV) 10000 100100 00 10 01 109
・(DOT) 10001 010111 00 10 11 13A
0(TV) 10000 010100 00 10 01 10A
100(TV) 10000 110100 00 10 01 10B
VOL + 10000 001010 00 10 01 114
CH RETURN 10000 111101 00 10 01 12F
TV CH+ 10000 100010 00 10 01 111
VOL - 10000 101010 00 10 01 115
AUDIO MUTE 10000 111010 00 10 01 117
TV CH- 10000 010010 00 10 01 112
MENU RETURN 10000 001011 11 10 01 1F4
MENU ON/OFF 10000 000001 00 10 01 120
UP 10000 111010 10 10 01 157
LEFT 10000 101011 11 10 01 1F5
SET 10000 111011 11 10 01 1F7
RIGHT 10000 011011 11 10 01 1F6
DOWN 10000 000110 10 10 01 158
BLUE Key 10000 100011 01 10 01 1B1
GREEN Key 10000 010011 01 10 01 1B2
RED Key 10000 110011 01 10 01 1B3
YELLOW Key 10000 001011 01 10 01 1B4
Power On(only) 10001 010100 10 10 11 14A
Power Off(only) 10001 110100 10 10 11 14B
LAMP level 01111 110100 01 10 1E 18B
Input1 10000 101011 0 10 1 135
Input2 10000 11011 0 10 1 136
Input3 10000 111011 0 10 1 137
Input4 10000 101100 11 10 1 1CD
Input5 10001 1100 10 10 11 14C
Input6 10001 10 10 10 11 150
Input7 10001 101010 1 10 11 195
Input8 10001 111010 1 10 11 197
Input9 10001 10101 1 10 11 1AA
PC Direct 01111 100000 01 10 01 181
post #3519 of 3787
Try this binary to hex converter. It gave mt this for the first power command: 41A27
http://www.binaryhexconverter.com/bi...-hex-converter
post #3520 of 3787
I tried it, it corresponds with a few numericals, looks pretty laborious. Had a reply at RC that the old Sharp LCD commands from 2007 do work on the new 70". So, I'm going to attempt again.
Thanks for input!
post #3521 of 3787
Just wondering from those of you who started with the cnet calibration settings and liked them, what minor adjustments have you made?
I think the cnet settings look pretty darn good maybe just a tad dim or greyed out for my liking, just not sure where to start to correct this. I tried adjusting the color gamut to expanded and color tone from low to mid low. Just not sure if there is a better way to adjust the settings. Thanks
post #3522 of 3787
If you changed color gamut to expanded, you don't know what you are doing. I found CNET settings the worst. You need to have your TV calibrated before you will be happy with the picture.
post #3523 of 3787
I agree about the cnet settings being the worst, the YouTube settings work well for me!!
post #3524 of 3787
Can you ever actually be happy? I have a hard time when I am at my friends house who has one of these biting my tongue over the strobe effect during fast motion. I keep saying in my head that the picture doesn't flow like that on my hdtv. I finally got him to see it on a dvd, Spiderman II, when the first time spiderman appears because it was so exaggerated on the bd player, and I played it back several times for him.
BTW, Does these sets handle 24p well? We also were watching the Batman BDs, and I couldn't make up my mind.
I was able to get him to spring $75, for a open box panny bt210, to replace the no name dvd player he's been using for 5 years. (for the load times and picture quality, not the 3D since the 734u doesn't do that.) He just doesn't get that there's still a free Avatar disc with it.
post #3525 of 3787
I just got the 732 on Saturday, to replace my Sammy 55" A950 and so far I'm not impressed with the picture at all. I tried the Cnet settings, but hated them. The picture seems dull compared to the Sammy, no "pop" at all. I tried to adjust the settings (total newbie) to get a more vibrant picture, but whatever I tried makes the picture either too vibrant or too dull. For example, when watching golf, the grass is either a dull brownish/green or a fluorescent green. Very frustrated. Anyone have any suggestions on what settings to use to get a picture that "pops"?
post #3526 of 3787
Search YouTube quattron pro calibration
post #3527 of 3787
Set the color temp to mid high and make sure you are in movie mode and not dynamic. Color gamut should be on standard not expanded.
post #3528 of 3787
Thanks. There are a few. Is it the one fromrussiawlove?
post #3529 of 3787
I have to ask a dumb question here. When watching blue rays, are you getting full screen or is it boxed at top and bottom?
I could have sworn that 2 days ago when watching the new pirates movie it was full screen but now has the black border at top and bottom. I tried the stretch and dot by dot mode and it is still boxed. Maybe I'm losing it!
Am I missing something with the settings?
post #3530 of 3787
Yes
post #3531 of 3787
Yes
Let me know what you think, these are the settings I use and I couldn't be happier!!
post #3532 of 3787
I gave these setting a try on the movie mode, still have them there. It is pretty good, only complaint I see from my set is maybe just a bit to heavy on the blues and cyan. Whites seems to have a minor bluish hue to hit and silvers and grey have a slightly blue tint as well. I may try to tweak this a bit.
post #3533 of 3787
Most movies are widescreen aspect which is 2.35:1 to 2.76:1,which are not 1.78:1 (aka 16:9) ratio like the tv, so black bars top and bottom are common and normal. Some bd have intro or other material which have the screen filled. Some are reformatted to the 1.78 ratio.
post #3534 of 3787
I was playing with these settings a bit more and I found a more realistic picture by reducing the color from 8 to 2 or 3 and setting the color temp to mid. Overall, I think I like these settings for both blu-ray and Comcast HD cable.
Watched the Daytona 500 last night and it was incredible on this tv!
post #3535 of 3787
You must have had it set wrong the first time, POTC4 is indeed 2.35/2.40 so there will be black bars when set properly @ 'Dot by Dot'.
Jason
post #3536 of 3787
I tried these settings and the picture had way too much yellow. Everything was tinted yellow. I guess every set is different because I can't imagine anyone would like those settings. Thanks anyways though. I tried someone else's settings posted here and like them pretty much. Best I have found so far. Unfortunately, so far I haven't found any settings that come close to the brightness and vividness of the picture my Samsung 55" A950 puts out.
post #3537 of 3787
The cnet settings for me were to dull and to yellow
post #3538 of 3787
I hated cnet settings as well, but I was referring to the YouTube quattron settings, which were far too yellow.
post #3539 of 3787
I had similar issues, time to get a meter
post #3540 of 3787
I thought too much yellow was caused by having the extended color gamut enabled? If not, could be an adjustment to your white balance is in order. At any rate, there is nothing like doing a calibration with a good meter on your own set.
