AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › A handy audio tester
post #1 of 11
Hey Guys,
I made an audio tester that I think some of you would find helpful when troubleshooting audio gear, especially when working with equipment in a rack. It is basically an amplifier and a 500 Hz tone generator. It runs on 4 AAA batteries and shuts itself off after 8 min. It allows you to test if audio is coming out of a piece of equipment as well as passing a signal through. I did some internet searches and I cant find anything like it. If it sounds like something you would be interested in or if you can tell me where you've seen a similar device, let me know. Thanks
Attachment 207420
post #2 of 11
I thought I would get at least one person asking how much you want for one or maybe," I use this other thing when I'm troubleshooting" Maybe I posted in the wrong area.
post #3 of 11
There are lots of similar devices offered and many have several more features. Building one for yourself is a good idea as it saves money on functions you may not need that pro units offer. Congrats though on a good idea.
post #4 of 11
Can you give me a brand and model? As I stated initially, I haven't seen any similar devices. At least nothing under $100. Thanks
post #5 of 11
Let's see...
Ideal, Extech, Cables to Go, and Fluke, among several other manufacturers, sell kits that do just that and more for <$100. At Home Depot you can find one for <$40, and I love the one I picked up at Lowe's for $46.
post #6 of 11
I looked at the web sites for all of the manufacturers you mentioned and found nothing like what I've made. If you don't mind, could you give me a link to one of the items you've seen? Thanks
post #7 of 11
http://www.extech.com/instruments/pr...tid=2&prodid=9
They'll be under the cable tester / locators. All of these are "fox and hound" sets with a signal generator like you've described...
Jeff
post #8 of 11
They may not be exactly what you've made, but just clip the tone generator onto an RCA (or whatever) connector and you're off and running.
post #9 of 11
Those things are for finding and identifying wires, not for checking audio components. The signal from the tone generator is too hot to send directly into a power amplifier and the probe will sometimes pick up the audio from a tuner or cd, but it sound distorted which might be the problem that your testing for. I'm going to make a video of my product, and show you what I'm talking about.
post #10 of 11
Portable CD player or iPod with a 3.5mm-RCA adapter and a test disc. Or an iPhone and any number of audio test or tone generator apps (and a cable)... Sorry, just think there's a lot of DIY-grade solutions to this problem, and any pro would have serious tone/test equipment.
Jeff
post #11 of 11
Those tone generators put out about volt, which is line level. If you need mic level, a simple voltage divider, either homemade (2 resistors) or bought from Rat Shack would do what you need.
  Back to Forum: Home A/V Distribution
