Recently I've been having problems streaming Netflix (both HD and SD). I think it used to be better some time ago but I started streaming more recently so can't tell for sure. FWIW I am in Brooklyn, NY.
I stream via Sony 46" XBR9 TV connected via wired Ethernet. Internet service is Verizon FIOS 15/5.
It's always the same problem - streaming just stops, then sometimes starts by itself and stops again, sometimes starts and goes on for another 5-minutes. It's intermittent, doesn't make Netflix unusable but it is annoying enough that I want to do something about it.
I also tried streaming using my Sony BD player (460N) that is also connected via wire but it suffers from the same problem as TV. BD player seems to have the same software to stream Netflix as TV does.
Whenever this happens I can always continue watching on my PC and I never had an interruption on PC (HD and SD).
I called Netflix and they told me they see on their end that my internet connection to them is inconsistent and I have to talk to Verizon. If this is the case - how come I never have any interruptions on my PC?
I personally think that it is some kind of software issue between my TV and Netflix servers + the fact that buffer on TV may be too small.
Does anyone have any experience with similar problem? Do you think getting another streaming device can fix this problem? The only device I consider at this time is Roku. Or I can use my laptop connected to TV but this is a bit of a hassle.
