Originally Posted by
trenken
Yeah a bunch of those are posted on page 58 of this thread. I tried many of them. Most of them are way too grainy with all those noise options turned off. It looks worse than my 7 year old Aquos.
I just calibrated myself starting with the default standard settings and making some changes here and there, such as changing motion to clear.
Mine are below. It won't hurt my feelings if you don't like them, I just thought I would offer them up. What source are you viewing/testing with, when viewing this graininess? You shouldn't see any graininess with BD/HD sources. If you do, it's most likely not caused by the tv. I would start over, by resetting all your pic adj settings.
Setting Memory: [any]
Picture Mode: Customize Any
Backlight: 4 (TV) 3 (Movies)
Picture: 95
Brightness: 50 (TV) 49 (Movies)
Color: 50
Hue: 0
Color Temperature: Warm 2
Sharpness: 20 (BD)/ 25-30 (TV/DVD) / 40-50 (PC)
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot noise reduction: Off
Motionflow: Off (Note Below)
CineMotion: Off
-Advanced Settings submenu-
Black Corrector: Off
Adv. Contrast Enhancer: Off
Gamma: 0
LED Dynamic Control: Standard
Auto Light Limiter: Off
Clear White: Off
Live Color: Off
White Balance:
R-Gain -2
G-Gain -1
B-Gain -3
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturalizer: Off [grayed out]
i/p Conversion Preference: Quality [grayed out]
--Screen menu--
Wide Mode: Full
Auto Wide: Off
4:3 Default: Off [grayed out]
Auto Display Area: Off (Option greyed out when watching non-HDMI content)
Display Area: Full Pixel (1080i/BD/DVD) Normal (SD)
Screen Position: [grayed out]
Vertical Size: 0 [grayed out]
--Pro Picture Setup menu--
[all settings default/Auto]
--Home Menu>Settings>Preferences--
--Scene Select menu--
General
--Eco menu--
Power Saving: Off
Light Sensor: Off
If you prefer to use the 240hz Motionflow, for fast movies, change the Motionflow setting to Clear and, bump up the backlight about 4 notches (So, for BD: backlight from 3 to 7, brightness 50).
