AVS › AVS Forum › Audio › DIY Speakers and Subs › DIY subs - coming from dts-10 - 3k+ budget
DIY subs - coming from dts-10 - 3k+ budget - Page 2
post #31 of 102
Originally Posted by Ivan Beaver View Post
What is dts1 and dts2? If you are refering to the speakon connectors they are labele 1 +/- and 2+/-. 2 +/- is NOT used in the factory wiring-only pin 1 +/-.
Make SURE you do not have any filters engaged on your amp-a pretty common problem with low output bass
I do not have the speakon connectors anymore, just straight copper pair from the amp to the subs. How should I set it up? dts1 and dts2 are the two drivers in the dts-10
post #32 of 102
Make SURE the drivers are wired electrically out of polarity. That is the + of dts1 to the - of dts2 (and of course the opposite wiring on the other terminals).
This will put them physically IN polarity (due to the opposite mounting).
When you put a battery on the speaker cable both driver should move in the same PHYSICAL direction. One will more INTO the basket and the other will more OUT OF the basket. But they both will move INTO the same part of the horn.
post #33 of 102
That's the best description we've had yet for a topic that has confused many, many people. Thanks Ivan.
Curious to hear some impressions with the new driver in.
post #34 of 102
Hey guys - want to say I am loving it. Still clipping during big scenes, but only on bass drops/iron man type stuff, so maybe I will get a HPF for 10hz. Going to measure the DB tonight
post #35 of 102
You probably shouldn't be clipping. I've not clipped mine and have run mine very loud. How do you have it wired to your ep4000?
post #36 of 102
The EP4000 is in mono-bridged mode, with the parallel for single inputs (both channel yellow links will blink/light up, etc)
Channel 2 all the way down, channel 1 all the way up, it clipped like crazy, so now down to about 22 (2 or so oclock). The Onkyo is on no EQ, xover at 80hz, subwoofer channel at -11.5DB
A straight RCA to XLR from the Onkyo to the DTS-10.
+ from the ep4000 goes to + of the first driver and - to the second driver.
- from the ep4000 goes to - of the first driver and + to the second driver.
If I put a 9v battery against the wires, both cones move in the same direction while looking at it (eg one in, one out)
post #37 of 102
When I had a single DTS, my EP4000 was in bridged mode and it clipped a few times. When I added the second DTS10, I changed to parallel and haven't had the first hiccup out of the amp! I'd experiment with that.
post #38 of 102
Experiment with the two dip switches for parallel and stereo? I will do! I would like a second DTS too. I may end up still going for something customer with a higher DB output, with more punch but maybe not as low.
post #39 of 102
The DTS-10 sounds good, but not quite suiting for the the room. I am falling in love with higher output subs. I went and demo'd a meyer 650 and a 700, not really impressed with those either. Any DIY subs that have high-output? 20hz+ I believe would be fine. Just at my whits end :/
post #40 of 102
Do you still have your room bare concrete? If so, I would wait until you get all of the walls and sheetrock up. That may give you a world of difference.
post #41 of 102
Try an Orbit Shifter from JTR
http://jtrspeakers.com/home-audio/orbit-shifter-lf/
post #42 of 102
I had one of these bad boys in my room; and yes sir, output above 20hz to impress.
post #43 of 102
Here is one, the Cinema F-20, and if you can handle the size two of these should be quite effective above 20 Hz. Two of them would cost you around $300 to build...however, they are visually more imposing and require more space than many subs (DTS-10 included). One last point, if you desire output below 20 HZ, you should look elsewhere.
post #44 of 102
If you want just 20hz and above just build a THT for cheap.
post #45 of 102
Out of those subs, which would have the highest output for 20+hz? Budget really isn't to big of a deal. Listened to the meyer 650, 2x 18s, no good.
I definitely want to keep the Danley - if I could get something to compliment it, it'd be great. Looking into the THT now.
post #46 of 102
There are a few people who use this JBL pro-cinema sub. It has tremendous output > 25 hz. Room gain in a small room (domestic) would probably get down to 20 hz. Haven't heard it myself but its an inexpensive plain & simple brute. Two would be fantastic for just over 3 grand brand new. The driver itself is used in the latest Synthesis system (subwoofer) which costs quite a bit more.
TH221 could solve your dilemma.
post #47 of 102
Sorry this is the JBL unit: JBL 4645C
http://www.jblpro.com/pub/cinema/4645c.pdf
post #48 of 102
Are you sure your DTS-10 is in a good location? Before doing anything, you should place the DTS-10 in your listening position. Move your chair into another room, temporarily. Then walk around the room with an SPL meter to check sound pressure in different room locations and compare them with the output in the position you've had the DTS-10 at. You might be locating it in a room null.
If it's in a bad spot, then no subwoofer on earth will make you happy in the same position.
EricH still has two of the 2245 subs available, which is supposedly higher output and better sounding than the 2242 in the 4645c? Apparently, either would use a much smaller cabinet (10cu.ft.)
EricH's 2245's:
http://www.diysoundgroup.com/JBL_Group_Buy.htm
Subwoofer for hi-fi: 2242H vs 2245H
http://www.audioheritage.org/vbullet...245H.&p=227138
So, I thought the DTS-10 was comparable in output to the THT from 20-80hz. Am I wrong?
post #49 of 102
I wonder if Eddie is on to something. I've never had a sub before that was as sensative to all the variables. And there has been major performance swings in my room. When dialed in at its best, I don't feel a need for supporting subs like you mention. But there were times with the wrong EQ, position, or room treatment that I felt that way.
post #50 of 102
If you are keeping the DTS-10 in the system don't mix subs, build more DIY DTS-10's
Up your crossover on the avr and have a listen
post #51 of 102
I do have a chance to get another (or two more) DTS-10s for a decent deal.
I was thinking of trying to get the replacement drivers for the th221 and then putting them in a THT type of box. Any comments on this?
The DTS-10 does sound great, and the 10hz and up sounds great (definitely need a high-pass filter, going to try to build one, wish I could buy one) for movies like ironman, some flying scenes send some weird frequencies that make the sub sound like it's overdriving/clips the ep4000.
I will wait until I get the basement completely sealed, but even when I had it in a 12x14 room, I was left wanting more.
xfer right now is at 80hz
Thanks guys, really appreciate it again. I am an LFE freak!
post #52 of 102
The F-20 is a pretty similar design to the THT, and I have high-SPL measurements here. Based on the rising response I saw in the 1W measurements of a THT I posted here, the THT will have an edge on the F-20 above 40 Hz.
DTS-10 measurements here. The DTS-10 numbers were collected at 2M, so they are 6 dB lower than the 1M values (distance is doubled).
post #53 of 102
Any reply?
post #54 of 102
Any reply?
You really do need a highpass. Especially if your room is open to other areas and you only have the one DTS-10 to fill it.
I'd want it to start rolling off somewhere around 15Hz or so in your situation. 48dB/octave. Especially if you're a bass nut like me and you're pushing it to its limits often. I use a Reckhorn B-2 on my own tapped horn, but it can be tricky to get set up properly unless you loop it through a computer running REW while dialing it in.
The thing about a horn is, if it's run too hard below the corner you start getting into distortion land. The horn starts amplifying the harmonics, more than the fundamental. With no highpass, this could very well be what you're hearing when it sounds like it's clipping.
post #55 of 102
A horn for a 21" driver will dwarf the DTS-10. Especially if you load the driver properly (20 Hz +/- for the Fc).
With an EP4K, you are quite capable of overdriving the sub, and it is distorting/clipping/complaining as a result. Are your clip lights flickering? If not, the sub has reached mechanical limits. Highpass will help a lot. As OW said, horns do not play nice below Fc.
As others have said, placement will make or break any sub. The best sub in the worst spot will sound awful. The worst sub in the best spot will sound better, but placement alone does not work miracles....
For Highpass/EQ? I like the MiniDSP, but it is a little fiddly to set up. Simple highpass? The Mic2200 will do that, but to be honest - it costs nearly the same as the MiniDSP and does far less of what matters.
post #56 of 102
You guys are the best. My friend has a Reckhorn B-2, going to mess around with it. It's definitely clipping on some iron man scenes. This has to be it. I am running it hard, but when I had it in my room, I had some songs that would hit HARD on a frequency (it was _incredible_) when corner loaded. Sounds like I just need to do some more tweaking.
post #57 of 102
Hey lilmike, again, thanks for responding guys, in my quest for LFE glory!
It's the amp clipping, and I can hear the subs make a weird noise when it clips. I do _not_ believe the drivers are overdriven. They are capable of much more, but with certain sounds, it will clip and overdrive (possible that the EP4k is pushing all that sub 10hz). I wouldn't mind crossing it over at 15hz, especially if I can push it harder.
I am going to get the minidsp - I am a techie, so the idea of all those
tweaks and being able to try other's success tweaks is just amazing.
I can definitely run REW back through a laptop/PC in real-time down in the basement for tuning.
I can get those 2x 21" drivers, and I can do some decently complicated DIY stuff, especially with some friends who are willing, but not sure where to even start in building a cabinet for that. I wish I could just use the DTS-10 platform, but with 21" drivers instead of 12 - any ideas here?
post #58 of 102
A word of warning - unless you plan to measure each tweak on the B-2 with REW, avoid using the EQ part of it altogether. Just bottom out the subsonic knob with no EQ boost and see if that improves things for you.
The reason I say that is the B-2 does some odd things with the highpass once you start dialing up the EQ boost on it. You can actually get it to move the highpass down to the point it'll still be like you still have no highpass.
No EQ boost however, and the 10Hz subsonic setting on it should put you in the ballpark of where you want to be. If still not satisfied, raise it a bit and see if it helps any.
post #59 of 102
There's two parts to overdriving, thermal limits and excursion limits. It sounds like you're exploring the excursion limits. A highpass will help a lot. That's typically a good sign that you need more (or more capable) drivers to get the SPL you want. Bass takes displacement, and though they're burly, the 12s in the DTS-10 do have their limits.
Have a look at this, which is arguably the most complicated tapped horn fold out there in the wild, and we're not done with it yet. It is certainly the most complicated fold I've drawn up. This uses a pair of 15s, and it is HUGE. It also puts a few dB on the DTS-10, as would be expected. Did I mention it is HUGE?
Most of the 21s I've modeled don't go as low as the DTS-10, but they do get louder. They're gonna be in the 25 to 30 cubic-foot range as far as cabinet volume, which is beyond cumbersome for a sub that does not go much below 20 Hz.
Personally, I like the idea of multiple smaller cabinets, cause I gotta move them. Since I'm getting older, 20 cubic feet is pushing things.....
Consider - a single 15" driver in an 18-cubic-foot cabinet models at 123 dB at 20 Hz 2pi using a $250 (street price) car stereo driver. A pair model at nearly 130 dB, 2pi. Four? Assuming you had enough power to drive them (and you do...) they should exceed 130 dB in a 2pi setting at a meter. In a room? Over 130 at the couch, easily. If this is not enough, seriously, seek professional help.
If you want to get below 20 Hz, the same drivers can dig a little deeper (-3dB at 14 Hz), but give up ~5 dB of output capacity and require 12 more cubic feet of cabinet volume. Nothing ever comes for free.
post #60 of 102
Mike, since the tapped horn design utilizes both the front and rear energy of the drivers, is it fair to say that the displacement is doubled? In other words, the two 12" drivers in the DTS10 act similar to the displacement of four?
