RIght now I have the HD input connected to the Dish 6000 HD receiver, which puts out 1080i. Will this input take 480P?
Right now, I have my (non-progressive) DVD player hooked up to the DVD input. As owners of this set are aware, there are no discrete IR commands for switching inputs. This makes it pretty clumsy to switch input sources with IR macros.
What I want to do is get a progressive output DVD player, and build an external IR-controlled component video switcher that I can use to switch between the DVD player and the 6000 receiver. But can the HD input accept 1080i and 480p, and autosense between them?
Also, is the DVD input on the set 480i only, or will it take 480p as well>
TIA,
Barry
TIA,
Barry
