I bought this receiver and hooked up an AT&T Uverse receiver, Apple TV (3rd gen/2012), and an Argosy media player via HDMI (output is thru two Polk M3ii front speakers). I'm finding that the volume is quite low for output from these sources. If I play music from my iPhone via the Yamaha app (i.e. directly to the receiver), the audio volume is great. But with the same volume level on the phone, if I stream to Apple TV->receiver, the volume is very low. Also, the volume for the Uverse and media player sources are low as well.
I then plugged in optical cables from the Apple TV and Uverse receiver to the Yamaha and adjusted the configs for the two HDMI sources on the receiver to obtain audio from the optical inputs. No difference. So I'm ruling out HDMI as the culprit since optical also results in the same volume. I could of course crank up the volume on the receiver but that doesn't seem like the right solution and may also result in more noise?
Wondering if anyone has had a similar experience or can shed some light on what I can do to resolve this. Not sure if I should try another receiver, maybe a Denon 1912. Thanks.
