AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR
The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR - Page 59
post #1741 of 1962
Originally Posted by Hotscot View Post
When I change the volume an indicator appears on the tv screen showing the value in dB. Any way to stop that appearing?
Menu>Setup>Function>Display Set>Short Message Off
post #1742 of 1962
Thank you Mr. Bond.
post #1743 of 1962
Welcome, sir.
post #1744 of 1962
How do you get it to upconvert to 1080p? I do not see any menu options and the Video info shows native resolution being passed along without conversion. In the video setup menu I have Processing set to On, but does not seem to affect upscaling.
post #1745 of 1962
I don't use that feature, but according to the manual there is also a "Resolution" submenu item; the default is "Auto" to select a resolution "in accordance with TV resolution" which I assume means using the HDMI info returned from the TV set. I would guess that if your TV says it can handle a resolution that matches the receiver's input resolution that the receiver would pass that through rather than upscale, and that your TV probably says it can handle many different resolutions. Probably have to force an output resolution with the "Resolution" submenu (guessing though).
post #1746 of 1962
It only upconverts 480i and 480p. See owners manual for details.
post #1747 of 1962
Hoping someone can help, I picked this receiver up off Amazon 2 weeks ago. Everything was working flawlessly. While watching TV tonight there was a click (similar to when it powers on) and the center channel stopped working. I hooked up the speaker to another rec and it works fine; hooked up another speaker to the center channel and nada. Any suggestions?
post #1748 of 1962
Well since you already tested the speaker on another receiver and it works fine and your receiver is only 2 weeks old, I would suggest calling Amazon back up and doing a return/exchange.
post #1749 of 1962
Return it.
post #1750 of 1962
Thanks guys, that's what I was afraid of.
post #1751 of 1962
Good for you it happen within 30 days
post #1752 of 1962
Originally Posted by Bond 007 View Post
Welcome, sir.
Guys need help, I hv 4 inputs into my 671 HDMI ,and one out to my panasonic ARC HDMI 2 Input,Hdmi 1 in is STB,Hdmi 2 is another STB, HDMI 3 is WD Player while HDMI4 is Pana Bluray.My amp refuses to turn on when I on the Tv ,but when I remove the HDMI 1 STB box the system works perfect, Vierra Link works perfect,the TV ons the AVR ons and turned Off all Off. The moment I plug the HDMI 1 STB box the Tv error message come Pls check your HDMI settings/Feature not availiable, and ssytem of on and Off simaltanouesly fails.Pls help thanks.
post #1753 of 1962
It may be getting confused because you have 2 of the same component hooked up to it. HDMI control is a finicky thing. That's why I don't use it.
post #1754 of 1962
Is there a way to make the receiver play music without the tv being on? I have an HTPC that is connect to the receiver and I want to play music from it but do not want to leave the plasma tv on at the same time. Every time I turn off the tv all sound goes with it. I turned off ARC, HDMI control, tv speakers, and made sure amp audio is on. Anyone have a suggestion?
post #1755 of 1962
I dont use a computer with my 671 and I dont know what ind of tv you have nut it sounds like something in your tv settings is nit letting the signal pass through unless the tv is on.
post #1756 of 1962
Computer is HDMI directly to receiver which is why I do not understand why tv setting would even matter. I checked with the ps3 and the sound cuts out but comes back. Computer is running XBMC on Debian. It has weird issues like not filling up the tv in 1080p mode so it could be a computer problem. Tv is a Panasonic ST50 but since the ps3 worked I'm going to assume its not a tv setting.
post #1757 of 1962
I have the st50 also and from what you have stated agree that it sounds like a computer issue.
post #1758 of 1962
When I connect my iPhone 4 (IOS 6.1) to my RX-V671 (FW 1.39) using the front USB port I get the message "USB connected". When I select the dock input it says "No Device".
I canot play anything from the iPhone to the receiver via the USB connection.
Can anybody give me any advice on this?
post #1759 of 1962
Select USB input-- not dock
post #1760 of 1962
Silly me, I was selecting the inputs on the receiver itself, no USB showed up for somehow, only dock. Thanks!
post #1761 of 1962
Hey, I just recently bought this receiver and love it! I had a question though. When I turn the volume to say... -15db I smell a burnt electronics smell , which greatly concerns me so I turn the volume back down. I have a 3.1 setup at the moment with polk speakers and a kllipsche sub. The polk speakers are all 8ohms. Does anyone know if if this is bad? I am wondering and hoping this is just some burn off of the chemicals and resins on the components, since they have never been that hot before and that it will go away. Everything seems to work properly, but I am still very concerned. Any help would be greatly appreciated thanks!
post #1762 of 1962
If it's new I would say the smell should go away in a few days. How hot does it feel on top of the receiver? Also, do you have the main speakers set to SMALL since you have a sub? That will offload the bass to the sub and the receiver won't have to work as hard to reach a given volume.
post #1763 of 1962
Well i have had it for a month or two. I typically play it around -30 to -40db. I only smell it when much higher than that, but don't keep it up there cause im scared for it lol. I will look into the small speakers thing. However -15db shouldn't be a problem imo since it can go to +16.5. Just hoping its not slowly causing damage and in half a year or so something stops working. Btw the smell is kind of strong. I smell it from like 10ft away
post #1764 of 1962
How hot does it feel on top?
post #1765 of 1962
Hi to everyone, i hope someone can help me. I connected the xbox to my 671 via HDMI port. I noticed that sometimes the video blinks or flickers, just for a moment...like a noise or an interference.
I changed the hdmi cable, I tried another HMDI port but the problem is not solved. Strangely if I use the 671 in standby and pass-through mode the video is ok...If I turn on the ampli the problem reappears.
Ah, the MySky and BD player video signal are perferct (also via HDMI)...
Help! can someone help me? Valerio
post #1766 of 1962
If it only flickers once when you turn on the receiver it is nothing to worry about.
post #1767 of 1962
unfortunally, not once where I turn on the receiver...when the receiver is on the flickers appear...not continuously but at intervals...every minute, every 2 minutes, every 5, there is no rules...but the strange thing is that the problem doesn't appear if the receiver is in pass-through mode
post #1768 of 1962
Do you have the 671 video processing off?
post #1769 of 1962
yes, video processing off...I also tried to set this features on but nothing changed...:-(
post #1770 of 1962
I don't game and I dont have an xbox so Im just guessing here. Have you tried an xbox Forum?
