AVS › AVS Forum › Audio › Receivers, Amps, and Processors › The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR
The "official" Yamaha RX-V671 thread. 7.1-Channel Network AVR - Page 69
post #2041 of 2142
Agreed. Firmware 1.50 is out. Dont know if that will help or not though. Just an FYI.
post #2042 of 2142
Where might I find v1.50? Didn't see it on the US support site.
Sent from my AT100 using Tapatalk 4
post #2043 of 2142
Originally Posted by Ozzyuk1 View Post
Just checked with Yamaha uk and there is a firmware update 1.50 , awaiting email post from them with firmware attach . .
Sorry jeremygary. That seems to be a UK update.
post #2044 of 2142
See above.
post #2045 of 2142
Can't see it on UK site.
post #2046 of 2142
Changed out TV from a Sony to LG..everything runs thru the receiver..TV on HDMI2 and PS3 on HDMI1. Well when I turned on the old Sony the receiver would come and play on HDMI2..just like it was suppose to. Now when I turn on the new LG, receiver comes on but starts on AV4 then I have to change it to HDMI2 manually..how do I get it to start on HDMI as the old one.
post #2047 of 2142
My Vizio TV does the same thing b/c I am using ARC. That I am aware, there is no way to change this within the receiver b/c the receiver powers on to the desired HDMI input - but the TV switches it to AV4 b/c of ARC.
post #2048 of 2142
Well if I connect a toslink to AV4..I probably wont have to keep switching it back to HDMI2..strange tho..the sony was fine
post #2049 of 2142
That is a pretty common problem and your solution is what most people do.
post #2050 of 2142
[quote name="lamplighter" url="/t/1327107/the-official-yamaha-rx-v671-thread-7-1-channel-network-avr/2040#post_23682860"]Well if I connect a toslink to AV4..I probably wont have to keep switching it back to HDMI2..strange tho..the sony was fine[/quote]That is a pretty common problem and your solution is what most people do.
I have my Blu-Ray player on HDMI 1, DirecTV receiver on HDMI 2 and Xbox 360 on HDMI 3. I am running Toslink to AV4 for ARC from my Vizio TV, and the Vizio is set up for audio control. I still have to manually switch to whatever HDMI input I want after everything turns on.
Is there something else that I can do to avoid this?
post #2051 of 2142
Not that I know of.
post #2052 of 2142
That's what I figured - short of spending a few hundred on an IR/RF, macro-capable remote like a Harmony. For that amount of money, I can live with pressing an extra button.
post #2053 of 2142
I to will live with pressing the extra button...I suppose I could run a Toslink to AV4 an just use that...does Toslink support 5.1 ?
post #2054 of 2142
It supports 5.1, but not 7.1. Toslink only supports Dolby Digital and DTS, not Dolby Digital Plus or DTS-MA. Also, I believe you lose audio auto sync from the receiver if you do not use audio via HDMI.
post #2055 of 2142
If you use toslink only for the internal apps on the tv as suggested then 7.1 and DTS MA are not supported anyway. The only sacrifice would be DD+ and I doubt you could ever tell the difference between DD 5.1 and DD+ 5.1.
post #2056 of 2142
Somewhat confusing to me..but anyway I dont think its worth the trouble taking the TV down to run a cable behind the wall..as long as my wife learns which buttons to push Ill be ok:)
post #2057 of 2142
ARC?...I have my cable box to HDMI2 and PS3 to HDMI1 and HDMI out to TV. Simple set up..my question is when I connect the TV to the internet I get the video but the sound is still whats coming in from the cable box..I thought if the TV received sound it would pass it back to the receiver and I would hear that. Both ARC is set to on on the TV and receiver..any ideas.
post #2058 of 2142
Yes. Dont use ARC.
post #2059 of 2142
post #2060 of 2142
Simple and effective.
post #2061 of 2142
Maybe this will help.
post #2062 of 2142
And this
post #2063 of 2142
There may be other steps required to get ARC working, such as enabling external speakers on the TV. You also need to make sure the HDMI input you are using on the TV is capable of ARC. Most TVs only have one ARC input.
post #2064 of 2142
Yes..Ive checked both...
post #2065 of 2142
As others have indicated, ARC can be squirrelly. There is almost certainly some combination of settings that will work, although it may never work as well as you like. Optical is cleaner and more reliable, but if running the extra cable is not in the cards, then ARC will be the way to go despite its flaws.
post #2066 of 2142
Thanks..probably will do that,,when I feel like taking to TV down
Tom
post #2067 of 2142
Can anyone tell me if the 671 has HDMI pass thru
post #2068 of 2142
Yes. Even when its in Standby mode (Off).
post #2069 of 2142
I loose my Suboofer sometimes. I have to go in and reapply my YAPO settings and then its fine. Anyone else have this?
post #2070 of 2142
No. Do the settings actually change? What do you mean reapply them? Are you actually rerunning YPAO?
