Greetings
Thank you for your patience as I muddle through this receiver. Your input has helped me great with several "issues" but there are a couple more that could be "deal breakers". I SHOULD return this and exchange it for a RX-A810BL to upgarde to a system with pre-amp outs so I can use my ancient M-80 AMP but I THINK I like the 2 Zone system (kids can use palystion in home theatre room and I can rock out on the patio.)
1) Post 824 helped me get my sub to work in 2 channel mode (thank you) Now can I still use the YPAO mic and re-setup the room? (without it changing my settings for 2-channel)
I am currently using this system with (2) B&W mains, B&W center, JBL 2600's for front presence, and Polk t-15's for rear surround and a Velodyne VA1250X(Not using rear effect speakers at this time.)
2) I have successfully used my i-phone and can reach playlists, but have to set the iphone to shuffle BEFORE I connnect it, as I cannot find a shuffle button in the play control menu. The even bigger things, I'd much rather use a memory stick with music on it (not tying up my phone) but cannot for the life of me figure out how to shuffle using a memory stick. I have many memory sticks that I move between my boat and home but do not want to listen to the songs in the same order every time.
3) This is perhaps the biggest "problem" I cannot solve even with your help on another post. This might be "Yamaha centric" and won't be solved by buying the RX-A810BL. I recently purchased a Blu-ray disc that says it is 7.1 DTS-HD Master audio. I am using a current Playstaion 3 40Gb as my bluray source. It seems to me that the front panel should acknowledge that it is getting DTS-HD 7.1, but the speaker icon on the panel (blue speaker icons) will only show two mains, two rear surrounds sub and center. To get the front presence speakers to work I have to use a decoder which introduces delay and muddled sound. Again it seems to me that there should be a way to utilize my 7 speaker setup and take full advantage of what the disc setup says is 7.1 DTS-HS Master audio. Did I waste time buying and installing front presence speakers, or I am I just dense?
I'm sorry if I seem dense but my old RX-2095 would have an indicator that says DTS (not Cinema DSP)
Again thanks for your patience
John
John
