Just to inform you of my personnel devs.
I bought a P50V20M here (middle-east, I am expat) 2 weeks ago. Everything was fine (really a perfect picture), made light calibration, and enjoyed
After a few days, suddenly I got some buzz coming from the screen
. Went off after 20mn.
Second day, happened the same thing
Finally I spent 20h on internet to understand noise in smps, how to troubleshoot etc...
In between I found an extremely interesting document
from Panasonic Australia (this is available on the web if you pay for it)(I paid). I copy the some part of the text (I imagine original protected by rights):
I then dismantled the TV, made a lot of pictures of everything, overall and macros, and start analysing.
Outcome :
- Noise is coming at 90-95% from T201 tranformer
- By pressing windings, I removed a bit of noise
- By compressing the transformer from left to right (TV standing normal position), I could remove 90-95% of the noise
Then I closed the TV, knowing more or less what to do.
This morning when I looked at pictures, imagine what was my surprise when I found the "CRACK" they are talking about in the document.
I will put the link later on (just starting to post, not allowed yet).
Solutions :
- Replace P Board
- Replace transformer (but how to make sure it is not again a badly manufactured one ?)
- Fabricate a frame to hold the transformer (I will try this tomorrow).
My understanding :
- It is much more than 0.4% of TVs !!!!
- Problem is not so easy to reproduce : need to get to final operating temperature with a big power demand (whites)
- Even it is not there during 50h, it does not mean that it will not break later on (mine was working 2 weeks in a shop with very strong A/C like 19-20°C); I guess problem came later on as in my home it is roughly 24-25°C at this time (and the transformer is rather hot).
You can find all my posts in French in homecinema-fr (look for neopdp V20 nash35nash).
Hope it helps you !
. Went off after 20mn.Second day, happened the same thing
.Finally I spent 20h on internet to understand noise in smps, how to troubleshoot etc...
from Panasonic Australia (this is available on the web if you pay for it)(I paid). I copy the some part of the text (I imagine original protected by rights):Quote:
| Symptom : Loud Buzzing Sound Buzzing sound that varies with screen white levels Cause : The varnish coating on a small quantity (<0.4%) of T201 transformers (located on P Board) has leaked into T201 bobbin shaft. When TV reaches normal operating temperature, the varnish coating expands, causing a hairline fracture in T201 ferrite core. Core fractures causes either a very loud constant buzz sound evident at normal volume levels (vol=20) or variable buzzing sound dependant on screen white levels. It TV set is more than 20 hours old without this symptiom, then T201 is OK. T201 factory improvements were introduced as follows : TH-P50V20A Q*032**** onwards TH-P54V20A Y*035**** onwards TH-P50VT20A Y*041**** onwards Cure : Change T201 on P Board |
Outcome :
Solutions :
- Replace P Board
My understanding :
Hope it helps you !
