It's all in the title.
Does anyone here make their own speaker stands and why would you recommend I do or do not make my own.
My loungeroom is carpet unfortunately and the majority of all pre-made/overpriced speaker stands I have seen have extremely small bases, especially for an area with a lot of through-traffic as they could be knocked over.
Basically for $25 I can get 2 sheets of 18mm MDF cut into 900mm stripsx150mm ( 2 per stand x 4 stands ) and also get the bases and tops out of these same 2 sheets and would bevel the columns for support so it does not sway, add black paint and bam, speaker stands, 20cm surface for speaker and 30mm base.
Sound good or bad to anyone?
The speakers have soft pads to prevent vibration so I don't think the MDF would be very problematic.
