Originally Posted by
jimmius
Ok posting my entire product code ips panel bought in greece europe
32LK450- ZH.BEUYLJP
and the panel code visible from the vents at the back
320B2W7L016CE-L82B
LC32WUN
manufactured march 2012 assebled in Poland
If the naming nomunclature is the same as it is in Greece, then in theory you should have an IPS panel. In the US the product code "CUS
Y means it is an IPS panel. You have a "DEU
Y product code. This is just pure speculation though. The only real way to verify you have an IPS panel is with the loupe/marco lens/magnifying glass or trusting the panel information at Panelook.
As far as your panel ID goes, I couldn't dig anything upon Google or Panelook about it. I think you left a character out of the
I have a hunch if you double check it, you will see something closer to "LC320WUN".
