I am intrigued by the LK530 mystery. Where did you find this tv? It seems like a nice set. You noted that it has ARC, and previous posts have indicated it has SmartTV, which will be very nice if LG delivers on it's promises this fall. How do you like the SmartTV?
If I look for it on amazon, I get hits, but the product description states 520 everywhere, and the described features are clearly for the 520.
I'd keep it too if I had one.
If I may make a suggestion, set it up and make sure all is well and then just enjoy it for a couple of days before attempting any calibrations. If your LK is like my LD (47-520), there seems to be break-in period and the set actually gets better after a short while. That's what I did with mine and I think it cut down a bit on the constant tweaking. But then again, the temptation is great to start fiddlin'
i emailed LG an they told me it wasnt discontinued yet but that it was a special model made for places like walmart an sams club not that many made either if you find one keep it
