We're building a new home that will be net-zero-energy and would like to have an automation system that will enable saving as much energy as possible, as well as the conveniences of automation.
Ideally, everything we'd get should:
1) itself use very little energy
2) work as close to flawlessly as possible (i.e. not be buggy or work intermittently in certain circumstances)
3) look good in a high end home (for my wife to accept)
4) be viewable and controllable from a user friendly interface (that my wife could use)
5) be as inexpensive as possible!
In priority order, we need:
*A gateway device/system that supports as many devices and protocols as possible (e.g. z-wave, zigbee, wifi, etc.), and provides an extremely secure (since it may control door locks) and user friendly interface accessible via web, android, ipad, etc...
*Lighting controls that support LED, CFL, and wired fluorescent lighting, with wall switches that I imagine would be hard wired to a particular light, and remote controllable from other switches as well to create 3-way or 4-way switches).
*Thermostats that support heat pumps (multiple levels of heating and cooling)
*Energy monitoring devices for the whole house, by circuit, and for certain devices (e.g. the solar/electric water heater)
*Locks: My wife likes the Schlage locks (Z-wave). Are there any alternatives that are significantly better?
*Ability to add motion and light sensors as triggers
*Controllable shades
*Camera: for front door, etc.,
*Distributed audio: Sonos has been highly recommended. Any alternatives worth looking into? Ideally this would integrate with the rest of the system
*Home theatre: Not sure if this needs to tie in to the rest of the home automation system, but would appreciate hearing if there's a way to do so that makes sense.
I have a programming background, but now have a very demanding non-programming job that leaves little spare time. So I could spend a few hours programming and setting up the system initially, but couldn't spend a few days, and need a system where the bugs have been ironed out and is well supported. That said, my preference is not to pay a ton of money for someone to program the system for me, or for a proprietary system (unless getting a proprietary system is our only option for a system that works well and and looks good).
I've seen recommendations for various systems here, but am not sure which system and components would meet our needs best. I'd much appreciate any advice and recommendations!
