Berkline 12011 seats
post #1 of 5
I'm thinking of buying some of these. I would appreciate any comments good or bad.
post #2 of 5
my advice.
sit in em, for a while. if at all possible.
if i had done this, i would not have mine. (i don't have those)
post #3 of 5
I wish I could but no one has these close to me so I will have to rely on those that have them.
post #4 of 5
Unfortunately comfort is very subjective and even though the 12011's are very comfortable for my wife and I, they may not be for you. We bought them sight unseen since we were in the same boat, and luckily they work fine for us.
post #5 of 5
FWIW, our family is happy with 12011s.
We also bought from Roman without sitting in them. We had spent about 1/2 hour in 12003 Renos. As it turned out, we are happier with the 12011s. The seat base is more supportive and is contoured better.
However as the others have said YMMV. Talk to Roman. He knows his chairs and will steer you toward different chairs based on the information you give him on your height, weight, age and theater configuration.
