I bought today 100 feet GE Ultra pro (87649) speaker wire from Home Depot for $29. Before I cut, I want to make sure it is good wire.
I looked number of times on the label, but can't find gauage. How do I find the gauage of the wire? It looks thick. Is thick one good?
From Crutchfiled, I read the following
Also, keep in mind the distance between your receiver or amp and your speakers — long wire runs can cause significant power losses and thus require thicker cable.
You can use the following chart as a guideline:
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
It says to use thick cable. At the same time, they want to use 12 (LOWER NUMBER) gauage wire for more than 200 feet. What I am missing?
Do you think the wire I bought is good? I have at most 39 (9 height+ 21 long+9 height) foot distance from receiver to any speakers.
80 to 200 feet 14
