Originally Posted by
burton123
BTW i have a question, does heated seating a value for home theaters? What you guys think abou this feature? will it be a good feature or a feature that will never be used?
If you're not conditioning the space enough to provide decent heat, what about cooling for airconditioning the rest of the year? Granted, a below-grade room would probably stay cooler, and be colder to heat, so there's that to consider. We added a second zone to our basement system to allow conditioning the space properly.
That and I'm not sure your bottom is the place that's likely to be the coldest in a theater room. Heating a cold car seat is one thing, as it's likely going to have dropped down to the same temp as the outside air at night. But a theater inside the house shouldn't see that same kind of temp difference. And then you're also faced with having to add an electrical source to the chairs, if it's not already present.
