Looking at the graph below the blue is the digital RS SPL meter set to C-Weight with no calibration file loaded into REW and the C-Weighted SPL meter checkbox unchecked in REW. The green is with the cal file from HTS loaded (the one notnyt mentioned above) and C-Weighted SPL meter checkbox checked in REW (this only has an effect below the range of the .cal file though).
I believe when notnyt mentions C-weighted he means SPL meter on C-Weight and C-weighted SPL Meter checkbox checked in REW. I didn't check that configuration but it can be derived from what I did measure (it would be about 7dB low at 10hz and about 3dB low at 20hz).
Originally Posted by Ricci
RS meter...This is more confusing than ever.
When we say C weighting was used are we all on the same page that this means there was no cal file used with it and that the meter itself was set to C weighting, not inside of the audio program as some like REW allow( that should be unchecked)? This is how I understand it. Notnyt has shown that the RS is reasonable for bass measurements if setup in this manner. Lennon68 is this exactly how yours was setup for the measurement that shows a big discrepancy? What are each of you using digital or analog versions? I find it hard to believe that there would be that much of a variation between units.
Bosso was Illka implying that only the digital version behaved in that way?! Sheesh what a mess if that is the case.
With all of these meters getting shipped around if someone wants to send me one I will check it out.
