Originally Posted by
07pilot4me
so there definitely is a difference in the screen?? glad to hear this
. are you planning to get the 6500??
Well the panel is the same, just the D550 reflects a lot more than the D6500.
I was leaning towards the 6500 (6900 in AUS), I was thinking about the 550 but after comparing the two I will not be getting the 550 any more.
obveron
I can't find anything in product specifications that shows the D6500 has an AR coating the D550 doesn't have. The only difference is 10 point Cal and Samsung Apps. Since D550 can have 10 point cal with a simple hack, the only difference is apps.
I sure would like to see some evidence the D6500 has a coating the D550 does not. Otherwise it's hard to justify the $400-$500 extra for some silly apps.
You really need to get into a store and check them both out. For me, the difference was like night and day for the glare between the two.
Black levels seemed fine on both so I can't justify the jump in price for marginally better blacks
