I'm looking to work on a new sub project, and with the MFW-15's available at such a great price, I thought I'd take advantage of that. I just bought a Behringer EP1500 to power the sub(s), and now I'm in the process of deciding what kind of enclosure to build.
My room is about 1500cuft, and I use it for about 80/20 HT/Music. I'm looking to go with 2 drivers (although I'll get away with 1 if I can). The type of subs I'm looking at are, 2 sealed, 1 dual opposed, or 1-2 ported. I like the idea of sealed to make the box construction a bit simpler, and not to have to worry about a high pass filter (hopefully), but if there's enough of a case for a ported alignment I wouldn't have a problem investing in a Minidsp or BFD (I'll probably get one down the line anyway).
Budget is fairly simple. I've already got power, and I'm planning on about $180-190 for the drivers. I'd like to keep material costs under $100, which I don't think should be too much of an issue.
It's a fairly small space, so I don't exactly have room for something like the THT. I listen at about 10-20 below reference, so crazy SPL isn't a priority, although I would like to maintain decent levels when I eventually move to a larger space. Based on my situation, which of the possible choices I listed above would serve me the best? Or would something else entirely be better? I'm open to suggestions.
