I've just bought an amplifier which has output specifications as follows:
20Hz to 20KHz, 8ohm - 65Wx2
1KHz, 4ohm - 90Wx2
Max power, 8ohm - 100Wx2
Max power, 4ohm - 120Wx2
Peak power, 8ohm - 560Wx2
I want to connect 3 pairs of in-ceiling speakers to it.
1 pair will be in a room. The other 2 pairs in another room. The amplifier can control the volume for the channels independently.
I was thinking of using the following setup:
Room #1 - 1 pair of speakers (80W, 8ohm each speaker) - connect them in series (result 160W, 16ohm ???)
Room #2 - 2 pairs of speakers (80W, 8ohm each speaker) - connect each pair in parallel, then connect them in series (result 320W, 8ohm ???)
Is it ok?
Is there a better configuration?
Do you have suggestions for different speaker specifications?
Any help is very welcome!
1KHz, 4ohm - 90Wx2
Is it ok?
