AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Need Help On design my theater room
post #1 of 2
need some Ideas on
Placement of screen
Projector Distances From The Screen
the Walls are 9' tall
Screen 106 or 120
Surround sound 5.1 or 7.1
Projector will be a Epson 8350
Any Input form the Experts Thanks
post #2 of 2
You can check out the throw distance for your projector at projectorcentral.com. Many good projectors work with an 18' throw distance on a 10' wide screen. You could put the projector in the garage and fire through a port hole if you wanted to avoid noise.
If you go with a 10 foot screen you will probably want to do an acoustically transparent screen with speakers behind the screen. Otherwise your speakers are going to be crammed in the corners.
