Yes, Siggy makes valid points, but with little tact. There is not really much mystery as to why we are here sharing our experiences. This being a community of concerned owners, it should be expected that not everyone has a technical understanding of the problem. Are there some confused posts? Sure, what else is new around here???
The primary issue is "pops". From what I've seen, this would cover the vast majority of complaints here. Before contributing, people should of course try to educate themselves a bit as to what they look like.
We all see them. Therefore, we all should be perfectly capable of evaluating the result of the supposed "fix". Of course, it will be left to the more technically competent to characterize and quantify the results.
Sorry, but I don't think an understanding of stimulus is really a prerequisite for this thread. Have you had a look at the title lately?
Originally Posted by SiGGy
And there's actually two separate issues which require different testing.
One effects stimulus levels 0-20 ish and that's the "floating brightness" i.e. "brightness pops"
Another is "floating blacks" which only effects 0 stimulus level only.
If you don't understand what I just said here you probably really don't have a handle on the issue or how to look/test it properly. If you fall into this category you probably shouldn't contribute to this thread until you do get your head wrapped around it. While your help is nice, all your really doing it making it confusing for everyone else.
