AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Does your 2011 Samsung "D" plasma have brightness pops?
Does your 2011 Samsung "D" plasma have brightness pops? - Page 64
post #1891 of 2252
If you have upgraded your firmware and your see no POPS can you please post the model of your set and SETTINGS you have so we can compare them?
For those of us who did not get the OPTIMIZATION step I am wanting to see if maybe adjusting settings to your current settings corrects the issue with the right firmware installed.
post #1892 of 2252
Zoyd announced in this thread a Google spreadsheet that does exactly what you want.
http://www.avsforum.com/avs-vb/showthread.php?t=1389562
Larry
post #1893 of 2252
Okay folks. Here it is regarding the OPTIMIZATION issue - at least for me:
Martin: Hi, thanks for reaching out to Samsung tech support. How can I help you today?
Me: Thank you. I have a PN64D550 that is experiencing brighness fluctuations/pops. I was on 1018.1 and have been sent firmware to upgrade to 1019.5 which fixes the problem or is advertised to.
Me: Anyway, I did the upgrade and my understanding that in addition to the upgrade an OPTIMIZATION step occurs or is supposed to. The OPTIMIZATION actually corrects the issue.
Me: When I upgraded last night to 1019.5 - no OPTIMIZATION screen appeared and now the issue is still there.
Me: Can you show me how to force the optimization or do you need to send a service tech to the house to perform this?
Martin: Does this happen on all inputs (like DVD and cable box)?
Me: yes I am watching with HDMI from CABLE and from PS3.
Me: I somehow think something didn't toggle right and the optimizaiton step was fixed. On the AVSForum, everyone who is getting this firmware fix says that the firmware seems to have corrected the issue IF the OPTIMIZATION step occurs. Not everyone is gettting this though.
Me: I mean OPTIMIZATION step was skipped - not fixed.
Me: Someone else reported that 1018.1 upgraded to 1019.5 like me with same model did not work and Samsung is dispatching a tech to do something.
Martin: Just to confirm, have you got any USB from the Samsung with the firmware?
Me: yes i have the firmware file T-MST4AUSC 1019.5
Me: version info SWU_T-MST4AUSC_001019_I01_ES000_111202
Martin: Okay, I am checking the issue.
Me: Thank you.
Martin: I will be right with you.
Martin: Please hold on for a few more minutes, I am still working on the issue.
Me: No Problem.
Martin: Thank you.
Martin: I will file a service request so that current firmware will be sent to you.
Me: I thought 1019.5 WAS the current firmware.
Me: That's what the TV set now says on screen.
Martin: Please let me know your full name, contact number, email address, shipping address and serial number of the unit so that I can file the ticket.
Me: So what are you sending me if I have the current release?
Martin: Thank you for waiting. I'll be with you in just a moment.
Martin: We will send two USB drives, one for roll back to the previous version and one is for latest version.
Me: Which version will it roll back too? Can you explain please?
Martin: It will roll back to previous version.
Me: which version number? I was on 1018.1 before I did the update.
Martin: Yes, it will roll back to that.
Me: If you roll me back to 1018.1 and then reapply 1019.5 - that is no different than what I did already.
Martin: Now it will resolve the issue.
Me: Can you please explain to me how that will resolve the issue if I go back to the very release I was on?
Martin: I'm sorry for the delay. I'll be right with you.
Me: Thanks.
Martin: Please wait for a while I am filing the request.
Martin: You will get it with in 7 to 14 business days.
Me: But, what about my question? I don't understand why rolling back to the version last night only to re-apply the same upgrade will fix the problem?
Martin: Generally this fix the issue.
Me: So doing this will cause the OPTIMIZATON step to kick in?
Me: So you are saying that your documentation is stating that this is the fix for the Optimization step to kick in?
Martin: Yes, you are correct.
Me: If this doesn't fix the problem can CHAT help me or should I just call a technician for warranty repair?
Martin: It should fix the issue.
Me: But if it doesn't?
Martin: then you contact technician for warranty repair.
Anyone ELSE have luck with rollback and upgrading??
post #1894 of 2252
For those of you with the PN64D8000 that had success with the update can you do the following and list the info. I'd like to compare it to mine, which still has pops even after the update. Our friend zoyd believes a correctly updated logic board might be the culprit.
1. With TV on press mute + 7 +3 +7 + enter
2. Post your Logic SW Version and Logic SW Checksum from the display
3. Turn TV off and then on to get rid of menu
post #1895 of 2252
11-11-04
0xF54E
post #1896 of 2252
Just as a reference to yours, since mine didn't optimize and I still see pops, my info is as follows:
Logic SW version: 11-06-07
Logic SW checksum 0x2E12
post #1897 of 2252
Originally Posted by David_B View Post
11-11-04
0xF54E
Ok, mine:
Logic SW Version 11-06-07
Logic SW Checksum 0x2E12
Sinku, ours is the same
Red, I'd like to see yours, since neither of ours has been successful
Any other PN64D8000 that have had successful updates, please try to post this information if you can
post #1898 of 2252
Ok, mine:
Actually very interesting....
Not sure what the bottom option in that menu describes but it's title is "logic usb d/l"
I clicked on it for the heck of it and it flashed "upgrading" but then immediately "fail"
post #1899 of 2252
Me: Thank you.
Me: No Problem.
Martin: Thank you.
Me: Thanks.
Interesting.. I have the same panel as you and went from 1018.1 to 1019.5 and didn't get optimization. Can you upload the rollback firmware when you get it so I can try the same thing. I need to roll mine back and re-apply the update as well.
I was told in chat this was not possible and they would need to schedule a service call.
Mike
post #1900 of 2252
It would be awesome if there eventually were a "brightness pops fix" thread for easy reference. Too much is happening here for my brain to handle.
post #1901 of 2252
Btw lol @ Martin. Sharp cookie
post #1902 of 2252
post #1903 of 2252
I hear you! I am glad I don't see them because this is way too confusing for me!
post #1904 of 2252
Holy crap...been away for a couple of weeks and came back to pages and pages of unread posts...
So if I get this straight...
As I'm Canadian...I can't get Samsung to send me the USB...
TiVoHD has graciously uploaded the software for PN64D8000 Owners (Post #1609 on Page 55).
Download this to USB, Unzip, Plug it in...Update.....if I see the "Optimization" then I'm good...otherwise I need to rollback and try again..
Anything missing?
post #1905 of 2252
Mine is:
11-11-04 and 0xF54E
No pops since the update.
post #1906 of 2252
I applied the 1019.5 update on page 56 to my PN51D550 (coming from 1019)
It flashed fine, but it's done three loops of the "Optimizing System" step now. It optimizes for about 10 minutes, then restarts the TV, and repeats. It's just started the third one.
And just shut off again.
And just as I finish this message, it finally stops optimizing.
Testing with the V for Vendetta blu ray (particularly the scene when he's taking over BTN), scenes previously filled with pops don't show any.
post #1907 of 2252
Originally Posted by mashles View Post
Mine is:
11-11-04 and 0xF54E
this is interesting, the same as DavidB. Red, if yours is the same as mine and sinku, then perhaps somehow our logic board did not get updated with this new firmware which might explain why we have not notice any changes in the pops. If true, then perhaps our boards might need to be replaced.
post #1908 of 2252
Ok, mine:
Mine is:
Logic SW Version: 11-06-07
Logic SW Checksum = 0x2E12
What does this mean Nesbo? Looks like I have the same as you.
post #1909 of 2252
Originally Posted by redrayderz01 View Post
Mine is:
This may all just be theory, but it is possible that our logic boards for some reason will not update with this new firmware. I don't know if that means our boards are faulty in some way or not....
Let me know what your tech says on Monday.
post #1910 of 2252
Okay, so i decided to try the fix on my 59d550 plasma, btw, its a plasma purchased in mexico and it worked so no probs there.
- i turned off the tv when plugged the usb
- Turned on the tv and the firmware was detected (update via usb)
- The install began, took 2 minutes first, turned off, then optimization process a minute more or less.
I have my doubts about the black levels, i can swear they were deeper but again its just me being paranoid and obsesive compulsive.
I checked the hockey game i recorded, and the pops were still there. So i checked two films i saw how the shadow areas turned bright all of a sudden.
First film had two issues, checked those, eliminated
Second film, Midnight in Paris, theres a shot of the Notredame cathedral and it tilts down to the protagonist, he is sitting in a bench. Theres obviously an exposure adjustment from the cinematographer, but the plasma used to pop brightness in a weird way.
I checked this out, and that weird adjustment in brightness was still there, the tree leaves all of a sudden turn from a dark green to a very light green.
This is where it gets weird, if i turn black level off, that pop is gone. But if i turn black level anywhwre from dark-darker-darkest, that pop will appear.
I turned black level off, and checked the hockey game again, most of the issues are gone, i can still see some drops or somethig weird when the flashes happen, but mostly is gone.
Again,i have doubts about the black levels, seemed to rise, but i just dont know.i have a light meter (conematographers sekonic lightmeter), but i dont even know how to measure the black levels on a screen.
Also, if i turn dynamic contrast on, that weird pop is gone.
Black level in darker, and cinemasmooth on, and the pop appears.
I hope i didnt lose any deep level, or a 3d feature over this fix.
post #1911 of 2252
We got some mad detectives on this thread lol. We will see what happens Monday, I don't have high hopes, but I bet they will just send another panel.
post #1912 of 2252
I saw it for the first time while watching Toy Story 3, but disabled eco and gone
post #1913 of 2252
Are you guys serious?!? It exists, and has been mentioned several times already.
I understand there are a lot of posts here, but if you don't even take a minute to simply review the page you are on, all you do is contribute to the clutter!
post #1914 of 2252
I've done some measurements on my logic board only update (I did not update the main board) and results are not good on my display.
Measurements taken with my i1D2 so absolute values may be off but the changes are real and accurate:
1. Measured rise in black bars of Casablanca clip linked in FBr discussion thread: 0.015 - 0.045 ftL (delta=0.03 ftL) (previous delta was 0.009 ftL)
2. Measured rise in black bars of another test clip I use (Cowboys and Aliens): 0.015 - 0030 ftL (delta=0.015 ftL)
The rises are less abrupt but bigger. I see two possible explanations for this:
1. Samsung tried to address the problem by raising black level to mask the abrupt changes.
2. There is further optimization that occurs with a normal upgrade as opposed to the way I did which was to just update the logic board directly.
We need someone with a meter to test a normal upgrade.
post #1915 of 2252
Thats not good.
post #1916 of 2252
Samsung tech just called me and they scheduled the appoint for Monday to check out my PN64D8000. She said the tech WILL be familiar with my situation, and that they do have a part in stock that should fix this. I asked her what that part is out of curiosity, and she said "main board". So hopefully it gets fixed Monday!
Will keep you all updated.
TGIF!
post #1917 of 2252
You need to turn the black tone setting OFF. Its similar to dynamic contrast--it degrades your picture quality, crushes blacks, and causes image fluctuation.
And as several have mentioned before, hockey is not a good test for pops. you have camera flashes and the ABL of the Tv kicking in, and that can fool your eye.
post #1918 of 2252
TGIF!
Keep us posted. I'm glad it seemed they were aware of the issue, unlike my original service center stating it had to with my signal changing for 480 to 720p?!?! Still waiting on a phone call from the new service center.
post #1919 of 2252
TGIF!
Good luck with that, the tech who replaced my main board (but for a different reason) was pretty much just a robot. Absolutely no knowledge of FBr, and just fed me the company line on everything I asked.
If you have your set calibrated, be aware that replacing the main board may require a totally new calibration, and could throw your grayscale out of wack. This is what happened to me, but not sure how common it is.
I'm still dealing with Samsung to sort out a fix for the crazy amount of red in Warm 2 mode after the repair. Out of the box, the set had decent grays without calibration. Now, calibration with a meter is a requirement.
post #1920 of 2252
The rises are less abrupt but bigger. We need someone with a meter to test a normal upgrade.
Boy, I'm hoping this is just a result of the non-standard upgrade.
I'm no expert....but I would think that even a casual viewer would be able to notice a black level change from the original .007-008 ftL of the 59/64" models..... vs rises towards .03 and .045 ftL....even if they were gradual.
.03 - .045 ftL should be creating a pretty significant "glow" of blacks in dark room viewing, no? That almost sounds like a bad LCD computer monitor type readings.
