AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Does your 2011 Samsung "D" plasma have brightness pops?
Does your 2011 Samsung "D" plasma have brightness pops? - Page 68
post #2011 of 2252
I am happy for You guys.My logic board shows 11-11-04 and I still got pops on 59D8000.Getting nuts
post #2012 of 2252
Originally Posted by LanceX View Post
ATTN - Zoyd comfirmed no black level change so update away please
I would be very careful saying this. The update has really trashed the picture on my D8000. The blacks are no longer black they are gray. Dark content never gets black. It looks like what they did was to make the tv stay in the popped state. Dark content has the light haze look to it now. I hope recalibrating will help. If not I will contacting Samsung and found out how to roll this back one Rev.
post #2013 of 2252
It's been a week since i updated my 59D7000 with the firmware posted here. I did get the optimizing message, and after a week I have seen no brightness pops and there has been no noticeable change in black levels.
post #2014 of 2252
awesome bry.
AGAIN ZOYD COMFIRMED NO TRUE CHANGE IN BLACK LEVELS. Those that cant optimize please see Zoyds thread on manually updating!
post #2015 of 2252
Try again after calibration (I'm assuming you have a meter to confirm?). The update in no way trashes the black levels. 0% pre/post black level stability has been confirmed on the D8000 and D7000 by me(51D8000) and Jason Widdon@HDJ owners thread (64D7000), not sure if Larry has measured it yet but his qualitative assessment was positive.
You will not be able to rollback the update without replacing your logic board.
post #2016 of 2252
awesome bry.
AGAIN IT TRASHED MY PICTURE. So which tv does zoyd have 7000 or 8000? This could be a difference. What would be nice is to have one of the pro calibrators with good equipment check the black level out. I also have a i1d2 meter like zoyd and it is not the best at the low end.
post #2017 of 2252
Post your D2 measurements of a 0% stimulus for comparison.
51D8000 pre=0.015 ftL, post=0.015 ftL
64D7000 pre=0.007 ftL, post=0.007 ftL
post #2018 of 2252
Zoyd you stated that "You will not be able to rollback the update without replacing your logic board". Now please explain to me why this would be? If you can flash it up you should be able to flash it down. Makes no sense.
post #2019 of 2252
I believe zoyd said this is because the logic board comes with factory-installed firmware that has never been released to the public (prior firmware upgrades have not modified, and therefore did not contain, the logic firmware). Once you upgrade it to this "popless" revision, you overwrite the old firmware, so there is no going back.
post #2020 of 2252
So Samsung in California called me today and offered me a refund because the technician that came yesterday (replaced mainboard) deemed the tv irrepairable. This was before I did the logic board update.
I declined the refund and told the lady that I adjusted the settings and can live with the pops. I DON'T want to start all over with another TV.
So far so good with the logic board update.
post #2021 of 2252
correct. Factory logic flash files are not available to revert to.
post #2022 of 2252
Oh and by the way, none of this would have been possible without the work of several people over at samygo.tv I would not have been able to extract those flash files if they hadn't first hacked the D series TVs and discovered the firmware encryption keys.
post #2023 of 2252
zoyd - I have a 64D7000 currently running FW 1011 and logic board version shows 2011-02-22. The TV is currently prompting me to install FW 1015. Do you recommend that I apply that 1015 firmware first, and then apply the logic board update? Or apply logic board first and then firmware?
post #2024 of 2252
You can just apply the 1014.6 FW here to save time and then recheck logic board version. If it isn't 11-11-04 then apply the logic board update. I'm not aware of any benefits for being on 1015 vs. 1014.6
post #2025 of 2252
Thanks. Are you saying it saves time because 1014.6 includes the 11-11-04 logic board update?
post #2026 of 2252
Does anyone have the roll back update for the d7000?
post #2027 of 2252
That is correct.
post #2028 of 2252
yep, but it does not always get applied, it's been hit and miss
post #2029 of 2252
I second this. I would like the roll back as well!!
post #2030 of 2252
Originally Posted by redrayderz01 View Post
Major, major props to Zoyd and Larry. Do you guys work for Samsung or something?
Lol
Tonight was the first night where I could actually enjoy some shows!
All the credit should go to zoyd. He is the one with the knowledge and experience in digital and analog electronics engineering. I'm just an old physicist -- the analog type -- that follows him around picking up his crumbs here and there.
Larry
post #2031 of 2252
Thanks zoyd and ampogo !
post #2032 of 2252
I measured my 64D7000 last night. The minimum luminance level was unchanged from before the logic update. It is still at 0.007-0.008 ftL.
A note to those that have to enter the service menu: Doing so will reset all your user settings to the factory default values -- including the Brightness.
Larry
post #2033 of 2252
Why?
post #2034 of 2252
Was having troubles last night updating my PND6900. Kept saying "no match". Have to try the "less_deepblack" file Tonight when I get home. Just seems plugging the USB in from Samsung would be less of a "hack" so to speak. Diving into this makes me uncomfortable, don't want to brick my tv. The thought of voiding my warranty is lingering in m head....
You guys are good though. Thank you for your efforts! Samsung seems to hang us out to dry with their lack of concern on the subject...
I'll update if I'm successful.
post #2035 of 2252
gotcha, I understand. Having not seen a rollback yet I am dubious Samsung will actually provide one but you never know.
post #2036 of 2252
I had the same issue, I also had to use the less_deepblack on mine and the "updating" process commenced. Good luck!
post #2037 of 2252
Thank you Zoyd, I no longer have brightness pops now that I updated my logic board. This was a long time coming, congrats to everyone now we can enjoy the tv fully.
post #2038 of 2252
So do us d7000 owners with firmware 1015 need the roll back USB?
post #2039 of 2252
Congrats! Feels good, doesn't it?
post #2040 of 2252
Great! glad to hear it.
@alexmanny01: You can wait till samsung sends you a rollback or update logic board as others are doing. your choice.
