If One Sub is Good, Are Two Better?
Alan Lofft, Axiom Audio
If your room has typical dimensions--20 x 14 x 8 ft., about 2,100 cu. ft.--one well-designed subwoofer with an internal amplifier equal in size to the full output of your receiver (full power for 1 channel + 1/8 power x the number of other channels) and a 10-inch or 12-inch driver should deliver solid deep bass extension and ample output for music and movie soundtracks. On the other hand, if the room is larger than usual (4,000 to 8,000 cu. ft. or bigger) or has a vaulted or cathedral ceiling, you should definitely consider running an extra subwoofer.
Big rooms, especially the "great rooms" so common in many suburban homes, really devour deep bass, so two subs will generate enough sound pressure to fill the place. They'll also give you smoother distribution of extended bass over several different listening locations. My colleagues and friends who have large vaulted-ceiling rooms all run dual subs. Taste plays a role as well. If you like your music or soundtracks really loud and deep, go for two subs. If you have a huge room and you want really loud sound and deep bass, then look at physically larger subwoofers with bigger amplifiers.
Read the complete article at HomeToys.com
