Ok guys I bought a new house last year and made sure to look for a house that had some future HT possibilities.
I found a tri-level that I think has the possibility for me to have a music room for 2 channel listening with my Maggies and an adjacent Home Theater.
I would store all the components in the utility room and use an IR repeater mounted at the front at the screen. The tandem space currently measure around 11x 18.
The garage is already dry walled but I would need to add a green glued layer for sound. Also running the conduit for cables to the other room will have to be done from the projector and the surround speakers.
Here are some floorplans and models I made with Sketchup:
What do you you guys think, especially the experts? Doable? I will go with an AT (debating ratio since I love sports and movies) so as to get the max size screen. The components seem to fit.
Any feedback is appreciated.
