Originally Posted by Sonic icons
Again, read the complete set of specs on the Onkyo website (http://onkyousa.com/prod_class.cfm?class=Receiver), including the part of the specs that I quoted directly and you apparently would like to ignore.
The power spec of the TX-NR609 is "Front L/R 100 W + 100 W (8 ohms, 20 Hz-20 kHz, 0.08%, 2 channels driven, FTC)", exactly the same as the comparable spec of the TX-SR608. The power spec of the TX-NR709 is "Front L/R 110 W + 110 W (8 ohms, 20 Hz-20 kHz, 0.08%, 2 channels driven, FTC)", exactly the same as the comparable spec of the TX-NR708.
I am aware that "6th category down" there is a spec that reads
"THD (Total Harmonic Distortion) 0.08% (Rated power) "
for the TX-SR608 and TX-NR708,
while the comparable spec reads
THD (Total Harmonic Distortion) 0.08% (20 Hz-20 kHz, Half power)"
for the TX-NR609 and TX-NR709. But the THD spec for the newer models does not indicate any degradation of amplifier performance, as compared to the older models, if we take into account all the specs for the amplifier section (rather than taking one line from the specs out of context and ignoring other specs).
In other words, the power and THD specs for the older and newer models can be paraphrased as follows:
older models, TX-SR608 and TX-NR708: the rated power (80 W or 100W) is produced into 8 ohm loads, two channels driven, with 0.08% or less THD from 20 Hz - 20 kHz; and, in addition, the THD is 0.08% or less at the rated power
newer models, TX-NR609 and TX-NR709: the rated power (80 W or 100W) is produced into 8 ohm loads, two channels driven, with 0.08% or less THD from 20 Hz - 20 kHz; and, in addition, the THD is 0.08% or less at half the rated power, from 20 Hz - 20 kHz
I have read all the specs. Please explain why one year's model would quote rated power, while the next would quote half power? What you "paraphrase" makes no sense, and would be pointless information.
